0 Replies Latest reply on Mar 17, 2014 9:18 AM by JRHall
    Drag an object side to side with limits
    JRHall Level 1
      I have a very specific need for a project  am working on.
      I need the used to be able to drag 3 layers, with a single touch, a set distance either direction on the x-axis.
      Ultimately I would like to have the 3 layers move at slightly different rates to create a parrallax effect.
      I figure the best way to do this would be to target the top layer for the dragging. Then code the other layers to move relative to the top layer's movement;
      something of the nature of  -
      if (layer1) moves in the x+ direction, then (layer2) moves (layer1 x -10) and (layer3) moves (layer2 x -10). And the reverse for x-.
      Does that make sense?
      Coming from animation rather than coding, I am finding it hard to get started with this one. I've picked up a lot very quickly so far but I can't seem to find anything anywhere to build off of.
      Thanks for your help,
      Justin
