12 Replies Latest reply: Oct 9, 2014 10:08 PM by rob wallis RSS
    Suggestions for FrameMaker 13
    ksoltys Community Member
      I missed the deadline for participating in the feature survey that Adobe sent me recently, so I put up a post on my blog about things I'd like to see in FrameMaker 13. Some of them are extensions of what I wanted to see in FrameMaker 12 (only a few of which were taken care of).
      The post is on the long side so I'm just going to link to it here:
      http://www.soltys.ca/blog/2014/03/suggestions-for-framemaker-13.html
      I will summarize my three major requests:
      • Seamless import and export of Microsoft Word files and content. Word is dominant in offices today and has been for years, but using content provided in Word format is a nightmare.
      • Better marker handling. Marker handling in FrameMaker is primitive. We need exapndable/collapsibe markers, editable in place, and a proper marker editing dialog.
      • A snapshot feature akin to that in Thirty Six Software's SmartDocs Word addin. Set variable values, conditional text settings, input and output directories and output formats and save them as a single object so we can switch between multiple views of a book with a single click.
      As much as I love FrameMaker, and I've been using it for 20 years, it's getting harder to justify it, especially because of my first point.
      Regards
      Keith
        • 1. Re: Suggestions for FrameMaker 13
          Eric Bleak Community Member
          May I also add putting a switch into the PASTE function so that you can set the default Paste as "Paste as Plain Text".
          95% of all PASTE operations I do require this,and going through the inane choice box is a constant irritant.
          Yes, a Frame user for 14 years, I really like using Frame, but wow, let's catch up with the times, shall we...
          Thanks for listening.
          Eric
          • 2. Re: Suggestions for FrameMaker 13
            Arnis Gubins CommunityMVP
            The paste hierarchy is controlled by the setting in the maker.ini file for:
            ClipboardFormatsPriorities=FILE, MIFW, MIF, RTF, OLE 2, META, EMF,  DIB, BMP, UNICODE TEXT, TEXT
            just move the "TEXT" component to the start of the list, i.e.
            ClipboardFormatsPriorities=TEXT, UNICODE TEXT, FILE, MIFW, MIF, RTF, OLE 2, META, EMF,  DIB, BMP
            and you';ll get what you want. FM's always worked like that.
            • 3. Re: Suggestions for FrameMaker 13
              Thanks for the help, but it still doesn't work...Still inserts as formatted text.
              And... Frame Interchange Format remains at the top of the list:
              Ready to keep going after it if you have any more ideas.
              Eric
              • 4. Re: Suggestions for FrameMaker 13
                Mike Wickham Community Member
                Don't forget to close FrameMaker before making changes to maker.ini.
                • 5. Re: Suggestions for FrameMaker 13
                  Oh you bet.
                  In the same way that it's not advisable to leave power on when you're removing circuit cards... (hopefully the reference from a past life is not too obscure...)
                  • 6. Re: Suggestions for FrameMaker 13
                    What you're displaying is the Edit > Paste Special (ctrl + shift + v) option . The maker.ini setting affects the standard Paste (ctrl + v) operation only, which is what you were asking about in your query.
                    Also, the list items in the Paste Special window are selectable by character matches, so "ctrl_shift + v", then "t" and Enter will paste in pure text.
                    • 7. Re: Suggestions for FrameMaker 13
                      Yes, and making that change (exactly as specified) in the maker.ini file did not change the default ctrl+v operation....It still pastes as formatted text, no matter what the source.
                      However..
                      ."ctrl_shift + v", then "t"
                      THIS is very, very, VERY helpful. Thank you!
                      Too bad there isn't an updated, printable version of the old Quick Reference Card available online. (The last one I have was Publication # 9003 7318.)
                      • 8. Re: Suggestions for FrameMaker 13
                        Hmm..., works for me (except for internal FM content, which always is in MIF format on FM's own internal clipboard). I can copy and paste from Word and all formatting is stripped when pasting using ctrl+v.
                        Check the user-specific maker.ini in the C:\Users\<login name>\AppData\Roaming\Adobe\FrameMaker\12 folder to see if there is a different specification there (as this maker.ini is read last and overrides the master one in the FM install location).
                        • 9. Re: Suggestions for FrameMaker 13
                          Yes! This is the function I need to change to a text-only-without-formatting paste.
                          Imagine comparing for objects, A, B, C, and D. I will write the comparison as A does not have the features of C, however, D and B do... If you imagine inserting a fourteen-character part number in the place of each of these capital letters, you can see how the lack of a text-only-without-formatting paste function can get really tedious - especially when inserting into tables that use a different formatting. .
                          Thank you all for the shortcut, it helps tremendously!
                          Eric
                          • 10. Re: Suggestions for FrameMaker 13
                            Eric,
                            Submit this request along with your use case(s) through the official channel: https://bugbase.adobe.com/index.cfm
                            Who knows, you might get lucky in the next version of FM.
                            • 11. Re: Suggestions for FrameMaker 13
                              DONE!
                              Thank you all very much for your help.
                              Eric
                              • 12. Re: Suggestions for FrameMaker 13
                                rob wallis Community Member
                                What I would like is the ability to use book level attributes to set running H/F values in TOC, LOT, LOF, IX etc.
                                It's annoying to have to manually change the generated files when the rest can be set from attributes at the book level.
