8 Replies Latest reply on Apr 24, 2014 12:04 PM by ksv000
    Simple: how to rotate a symbol onclick?
    pixelwrangler Level 1
      Well, my old Flash and AS skills seem to be pretty useless with Animate. Every resource online I have looked at goes on and on about making things jump around as the Timeline runs. That's not what I need to do.
      All I really need to know is how to use an onclick event to make something else on the stage move in a precise way.
      I have a symbol I'll call "wheel".  I have another symbol I'll call "button"
      When the user clicks on "button," I want "wheel" to rotate 45° around its axis. I can't find a listing of Edge code syntax anywhere.
      I opened the Action panel for "button". Not much help in that right hand menu.
      sym.$("wheel")  addresses the symbol I need - but then what? I could address this with CSS/JS, but surely there's a SIMPLE way to do this with Edge??? Or should I go back to Flash and use the HTML stage feature?
      If it wasn't for the ubiquity of iOS devices, I wouldn't have had to abandon Flash development. But both Flash CC/HTML and Edge are looking pretty clunky as real tools for cross-platform animation as compared with just doing all the scripting by hand...
      Am I missing something really obvious?
        • 1. Re: Simple: how to rotate a symbol onclick?
          resdesign Adobe Community Professional & MVP
          you can put the code in compositionReady and it could look like this:
          var i=0
          sym.$('button').click(function(){
                    i+=30;
                    sym.$('wheel').css('transform', 'rotate('+i+'deg)');
                    sym.$('wheel').css('-ms-transform','rotate('+i+'deg)'); /* IE 9 */
                    sym.$('wheel').css('-webkit-transform','rotate('+i+'deg)'); /* Safari and Chrome */
          sample here:
          https://app.box.com/s/48bmkcj045s6q6rfz77y
          • 2. Re: Simple: how to rotate a symbol onclick?
            Thanks, that was what I had in mind ... but ... if I'm going to have to hand code all of that stuff (all of my Symbols are imported graphics, so I don't care at all about drawing things with HTML5/CSS), what's the sense of bothering with Edge at all? To serve as a compositionReady "container" for hand-coded animation?
            Edge seems pretty limited as a production tool if it won't give me access to simple animation snippets (such as there are in the Flash CC HTML tools...) AND won't even address the cross-browser problems with any kind of "automation." I just don't see the point...
            I think the transition away from Flash (which is entirely NOT Adobe's fault) is still awaiting something that could be really useful in creating cross-browser animation. Actionscript has no professional successor, at least that I can see.
            • 3. Re: Simple: how to rotate a symbol onclick?
              ksv000
              hello,
              thank you redesign for the tips for a similar question i had. i modified the code to click every 90 degrees when i click on text i have set at those points (right, left, upright). however, i'm finding that i need the clicking of the text to correspond with the exact position of the dial. for example if i keeping click left, it keeps going every 90 degrees. i need to be able to jump from north to west, etc and have the dial land there.
              thanks for your help.
              var i=0
              sym.$('Left').click(function(){
                        i+=90;
                        sym.$('spin_dial').css('transform', 'rotate('+i+'deg)');
                        sym.$('spin_dial').css('-ms-transform','rotate('+i+'deg)'); /* IE 9 */
                        sym.$('spin_dial').css('-webkit-transform','rotate('+i+'deg)'); /* Safari and Chrome */
              var i=0
              sym.$('Right').click(function(){
                        i+=180;
              var i=0
              sym.$('Upright').click(function(){
                        i+=90;
              • 4. Re: Simple: how to rotate a symbol onclick?
                On top of my head, seems like you should use minus instead of plus to go in the other direction.
                can you send me a link to your files?
                • 5. Re: Simple: how to rotate a symbol onclick?
                  ksv000 Level 1
                  hi redesign,
                  thanks for your rapid reply.
                  instead of relying on just a turn on # of degrees command,  i want the clicking of the text around the dial to move it to those specific points.
                  kim
                  https://www.dropbox.com/s/hr5uptvhphpxru8/sts.an
                  • 7. Re: Simple: how to rotate a symbol onclick?
                    You made the mistake of having i=0; several time in your code. Please change you code in composition ready to:
                    var i=0
                              i+=90;
                              i+=180;
                              i-=90;
                    sym.$('downright').click(function(){
                              i-=180;
                    • 8. Re: Simple: how to rotate a symbol onclick?
                      ksv000 Level 1
                      i think i'm approaching it in a different way for now. thanks for your extra eyes!
                      kim
