4 Replies Latest reply on Mar 19, 2014 2:59 PM by PECourtejoie
    如何设置双击鼠标的快捷键?How to set  the shortcut keys "double-click"?
    chen1110103
      在cs3版本以后,ctrl+双击空白工作区新建画布(ctrl+n)的功能被取消了,变成了选择打开已有的文件(ctrl+o)。这个功能不好用,因为从窗口选择文件打开比直接在工具外拖放 进来打开的效率低。
      如果用ctrl+n来新建的话,需要努力张开整个左手手掌并往左旋转倾斜,或者是两个手配合,对于长时间操作的从业人员来说,增加了手部疲劳。
      既然双击已经有ctrl+o的效果了,那么ctrl+双击也是ctrl+o的话就重复了,如何设置回cs3版本以前的操作方式,让ctrl+双击可以新建画布呢?
      I am sorry ,this is google translate!
      After cs3 version, ctrl + double-click on a blank area to create a new canvas (like ctrl + n) function is canceled, becomes choose to open an existing file (like ctrl + o). This feature is not available because lower than  directly from the open window  select the file efficiency.
      If you use ctrl + n to create a new case, need to open the entire left hand and left tilt rotation, or with both hands, for practitioners prolonged operation, increasing the hand fatigue.
      Now double-click  have the effect "ctrl + o", and then  ctrl+double-click  also repeat  the effect "ctrl + o".and how to set back to the previous version cs3 mode of operation, so that you can press ctrl+double-click to create the new canvas?
      how to set ctrl+double click = ctrl+n?
