3 Replies Latest reply on Mar 18, 2014 12:33 PM by gkaiseril
    Hide fields
    Efe
      I have 14 text fields named "box1, box2, .... box14" and a text field named "final".
      I want to hide "final" until all 14 boxes have an input.
      How do I code that?
      Acrobat Pro XI
        • 1. Re: Hide fields
          You need to use Custom JavaScript coding.
          I would use the custom calculation javascript for the "final" filed.
          function GetField(cName) {
          // get field object fro cName field with error reporting;
          var oField = this.getField(cName);
          if (oField == null) app.alert("Error accessing field " + cName);
          return oField;
          } // end GetField funciton;
          var bFinal = true; // logical to indicate all fields completed;
          for(i = 1; i < 15; i++) {
          if(GetField("box" + i).value == GetField("box" + i).defaultValue;) {
          // field's value same as default value so not completed;
          bFinal = false; // set not ready;
          } // end value not equal default value;
          } // next field;
          if(bFinal == true) {
          var oFinal = GetField("final");
          oFinal.display = display.visible;
          var oBox;
          // hide all "box#" fields;
          for (i =1; i < 15; i+=) {
          oBox = GetField("box" + i);
          oBox.display = display.hidden;
          } // next field;
          } // end bFina true;
          • 2. Re: Hide fields
            Efe Level 1
            Hey, thanks for it! However I get syntax error on oBox lines, also says missing ) before "// field's value same as default value so not completed;" part. Couldn't manage it :/
            And I don't need any error until the boxes are all filled. Just need it to be hidden.
            • 3. Re: Hide fields
              The error message includes a line number that might be helpful.
              I have not created a form to check the script.
