3 Replies Latest reply: Jun 2, 2014 7:23 AM by bfento RSS
    Web Content "Scale Content to Fit" does not work???
    DMD-Ryan Community Member
      I don't understand why "Scale Content to Fit" does not work with "Web Content" frames?  It does nothing but give you a cropped view of the site when viewed on the iPad.
      It works fine with the desktop viewer (Preview on Desktop) though.  Why is this and does anyone have an answer or a solution to make it work?
      Does it work for anyone else?
      Any feedback would be nice.
      Ryan.
        • 1. Re: Web Content "Scale Content to Fit" does not work???
          bfento Community Member
          Same problem here.
          I create a 768x1024 Edge animation to be used in the vertical rendition of the article. Then I create a proportionally scaled down frame in the horizontal rendition using the "Scale Content to Fit" and link to the 768x1024 published Edge content. It should work, right? But it doesn't. My content is much smaller than the frame and there remaining 20% or so space inside the frame is a shade of grey...
          I'm going to see if I can somehow fix this by opening the file in Dreamweaver, but I really should have to do so if it works fine in the 768x1024 frame.
          Is there something obvious that we're overlooking?
          Thanks!
          • 2. Re: Web Content "Scale Content to Fit" does not work???
            Bob Levine CommunityMVP
            I think you’re far better off creating a second version of that animation but this is just another reason not to do dual orientation. Too much work for zero return.
            • 3. Re: Web Content "Scale Content to Fit" does not work???
              Thanks Bob. I agree.
              I've found other threads discussing this same issue, and there is no easy fix solution.
              We've been including the animation in the vertical rendition only with a "rotate to view animation badge" in the horizontal rendition, but I was hoping there was a simple solution. It's up to the decision makers now to decide whether they want to invest in the animation twice (not quite twice, since I can copy/paste it from the original animation, but I still have to resize it, etc...).
              Thanks again!
