3 Replies Latest reply on Mar 19, 2014 8:09 AM by Magus069
    Make subform visible by making a selection in a dropdown
    donn44157260 Level 1
      I am trying to make a subform visible if the user select yes from a dropdown.
      I have the following setup on the form
      Subfom1 -Dropdown with 3 entries, Select, No Yes.
      Subform2 – Text field for users to enter test
      The code I have been trying to use is
      execEvent("change"); In the Initialize event and in the change event I was using
      if (xfa.event.change == "5") {
          subform2.presence = "visible";
      When I try the form, nothing happens,. There is no errors in the Javascript debugger
      Any ideas would be helpful.
      I am running Adobe LiveCycle Designer 8.05.2073.1.374024
      Chomp
        • 1. Re: Make subform visible by making a selection in a dropdown
          Magus069 Level 4
          If your default value is set to select you can write in the change event
          if (this.rawValue == 5)
          • 2. Re: Make subform visible by making a selection in a dropdown
            Thanks Robert;
            I did as you suggested and I still cannot get the field to become visible. I tried a couple of things.
            (1) In the Initialize Event - execEvent("change");
            In the Change Event - if (this.rawValue == "1") {
            why_subform.presence = "visible";
            The subform did not become visible nor was there an error in the javascript debugger
            (2) Took execEvent("change"); out of the Initialize Event.
            Initialize Event blank
            Added to the Change Event
                why_subform.presence = "hidden";
            if (this.rawValue == "2") {
            (3) Added execEvent("change"); to the Initialize Event
            Preference defaults are set to – Preview = Interactive Form
                                                             XDP Preview Format – Adobe 8 (Dynamic) XML Form
            • 3. Re: Make subform visible by making a selection in a dropdown
              Magus069 Level 4
              if you have specified values in your dropdownlist,
              i think you have to check if the value is 1 as an integer not a string
