4 Replies Latest reply on Mar 25, 2014 4:22 AM by cfjedimaster
    How to sync two different Edge Animation's on a website?
    Steve90 Level 1
      Hello everybody,
      I've made 2 animations on a Website and I want to synchronise these.
      The 2 animations have to start simultaneously.
      But the animation which loaded its content starts first and then the other.
      The difference now is noticable and will be more on slower internet-connections.
      How can I achive this in Edge Animate, or do I need Java-Script in my ".html"-file?
      (Hope not because I can't script )
      Thx
        • 1. Re: How to sync two different Edge Animation's on a website?
          hemanthR Adobe Employee
          Check out this tutorial http://blogs.adobe.com/edge/2012/05/15/bootstrapping-edge-compositions/
          With bootstrapping you can start animation only after both aniamtions have finished loading their sources.
          • 2. Re: How to sync two different Edge Animation's on a website?
            Steve90 Level 1
            Hi Hemanth,
            thank you for your reply.
            I imported the animations on 2 different locations like this:
            <div id="content">
                          <div id="teaser">
                                    <div id="samsung">
                                      <object id="EdgeID" type="text/html" width="169" height="420" data-dw-widget="Edge" data="edgeanimate_assets/samsung/Assets/samsung.html">
                                      </object>
                              </div>
                              <div id="text">
                              </div>
                              <div id="apple">
                        <object id="EdgeID2" type="text/html" width="151" height="368" data-dw-widget="Edge" data="edgeanimate_assets/iphone/Assets/iphone.html">
                        </object>
                      </div>
                          </div>
            </div>
            _______________________________________________________________________________
            From here the post is edited, because I tried it without the <object> tag, used the "bootstrapCallback and included the 2 animations with all necessary files.
            Unfortunately now my head-area explodes with java scripts.
            I changed my file like this (head-area):
            <script type="text/javascript" charset="utf-8" src="assets/iphone_edgePreload.js"></script>
            <script type="text/javascript" charset="utf-8" src="assets/samsung_edgePreload.js"></script>
            <style>
                      .edgeLoad-EDGE-109535821 { visibility:hidden; }
                      .edgeLoad-EDGE-141942318 { visibility:hidden; }
                      #Stage { visibility:hidden;}
            </style>
            <script>
            var countComps = 0;
            AdobeEdge.bootstrapCallback(function(compId) {
                      countComps = countComps + 1;
                                if (countComps == 2) {
                                          comp2 = AdobeEdge.getComposition(compId).getStage();
                                          $("#Stage").css('visibility', 'visible');
                                          comp1.play(0);
                                          comp2.play(0);
                                else {
                                comp1 = AdobeEdge.getComposition(compId).getStage();
            </script>
            ... and in the body:
            <div id="content">
                 <div id="teaser">
                      <div id="samsung">
                           <div id="Stage" class="EDGE-109535821"></div>
                      </div>
                     <div id="text"></div>
                     <div id="apple">
                            <div id="Stage" class="EDGE-141942318"></div>
                     </div>
                  </div>
            </div>
            • 3. Re: How to sync two different Edge Animation's on a website?
              Steve90 Level 1
              I edited my last post to explain better what I did and deleted all unnecessary informations.
              Now it seems that it starts after preloading both compositions but it plays only the first animation. (comp1.play(0);)
              I did this with my basic scripting-skills and I don't know if this is a good solution and where the fault is.
              Now I need help again.
              Thank you in advance.
              • 4. Re: How to sync two different Edge Animation's on a website?
                cfjedimaster Level 3
                I believe you want to add
                var comp1;
                var comp2;
                right after var countComps; as currently the variables exist only for the duration of the callback.
