5 Replies Latest reply on Mar 19, 2014 12:26 PM by Jump_Over
    Issue with script after upgrade - "HarbsTestMenu"
    kenzierlemmons
      We upgraded our InDesign from CS4 to CS6 awhile ago, and I've just found a script that we've made no long works properly.
      It was authored by a former employee, and I'm not terribly versed with scripting myself, so I wanted to see if you guys could help me out.
      Here are his instructions:
        • For any errors or problems you may encounter using the sublimation menu, the script is located in C:\Program Files (x86)\Adobe\Adobe InDesign CS4\Scripts\XHTML For Digital Editions\startup scripts\SublimationMenu.jsx.
        • The sublimation menu requires that the PlaceHolder_.ai files are located in C:\Program Files (x86)\Adobe\Adobe InDesign CS4\Scripts\XHTML For Digital Editions. Without these files the menu will not be able to add new pages correctly.
        • If any problems somehow arise with the menu installed on your computer you can find a back up with all of the necessary files located in the Print Templates > Master Files > Scripts folder
        • To remove the sublimation menu remove the script from the startup scripts folder on your computer. Then open InDesign and press CTRL+ALT+SHIFT immediately, if performed correctly a pop up should appear asking if you'd like to delete InDesign Preference files, click yes.
      The folder "XHTML For Digital Editions" does not exist for the new install of CS6. I placed the file in SublimationMenu.jsx file in \Adobe InDesign CS6\Scripts\startup scripts\ and the (8) different PlaceHolder_.ai files in \Adobe InDesign CS6\Scripts\
      However, when I used the menu to add new pages it gives me the following error:
      I'm not sure why it is looking in the Documents folder rather than in one of the many the Adobe folders.
      Here is the content of the script:
      #targetengine "HarbsTestMenu"
      menuInstaller();
      function menuInstaller() {
          // SET THE FILES THAT ARE TRIGGERED BY MENU ITEMS
          menuItem1Handler = function( /*onInvoke*/ ){
      var myDocument = app.activeDocument;
      var myPage = myDocument.pages.item(-1);
      app.activeDocument.pages.add();
      app.activeDocument.activeLayer=app.activeDocument.layers.itemByName("PRINT");
      myDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.inches;
      myDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.inches;
      if(app.activeDocument.metadataPreferences.documentTitle == 'Coffee Mugs NoWrap'){
      var myRectangle = myPage.rectangles.add({strokeWeight:0, geometricBounds:[0, 0, 3.8125, 8.0625]});
      myRectangle.place(File('PlaceHolderMug.ai'));
      myRectangle.resize(CoordinateSpaces.INNER_COORDINATES,AnchorPoint.RIGHT_CENTER_ANCHOR,Resi zeMethods.REPLACING_CURRENT_DIMENSIONS_WITH,[290.25, 274.5]);
      myRectangle.move([9.8438, 0]);
      myRectangle.locked ^= 1;
      myRectangle.move([4.9774, 0]);
      myRectangle.move([0.1181, 0]);
      myRectangle = myPage.rectangles.add({rotationAngle:180, strokeWeight:0, geometricBounds:[0, 0, 3.8125, 8.0625]});
      myRectangle.move([4.1493, 8.5]);
      myRectangle.move([9.0226, 8.5]);
      myRectangle.move([13.8681, 8.5]);
      if(app.activeDocument.metadataPreferences.documentTitle == '4in Clocks'){
      var myRectangle = myPage.rectangles.add({strokeWeight:0, geometricBounds:[0, 0, 4.125, 4.125]});
      myRectangle.place(File('PlaceHolder4inClock.ai'));
      myRectangle.move([0.2222, 0.3472]);
      myRectangle.move([6.6597, 0.3472]);
      myRectangle = myPage.rectangles.add({strokeWeight:0, geometricBounds:[0, 0, 2.25, 8.25]});
      myRectangle.place(File('PlaceHolderPlaque8.ai'));
      myRectangle.move([1.375, 5.8611]);
      if(app.activeDocument.metadataPreferences.documentTitle == '5x7 Signs'){
          var myRectangle = myPage.rectangles.add({strokeWeight:0, geometricBounds:[0, 0, 7.0625, 5.0625]});
          myRectangle.place(File('PlaceHolder5x7Sign.ai'));
          myRectangle.move([0.2535, 0.7852]);
          myRectangle.move([5.7181, 0.7852]);
      if(app.activeDocument.metadataPreferences.documentTitle == '8in Clocks'){
          var myRectangle = myPage.rectangles.add({strokeWeight:0, geometricBounds:[0, 0, 8.1389, 8.1389]});
          myRectangle.place(File('PlaceHolder8inClock.ai'));
          myRectangle.move([0.1875, 1.4375]);
      if(app.activeDocument.metadataPreferences.documentTitle == 'Plaques'){
          var myRectangle = myPage.rectangles.add({strokeWeight:0, geometricBounds:[0, 0, 2.25, 8.25]});
      myRectangle.move([1.375, 0.3958]);
      myRectangle.move([1.375, 3.1181]);
      if(app.activeDocument.metadataPreferences.documentTitle == '8x12 Signs'){
          var myRectangle = myPage.rectangles.add({strokeWeight:0, geometricBounds:[0, 0, 8.15, 12.15]});
      myRectangle.place(File('PlaceHolder8x12Sign.ai'));
      myRectangle.move([0.925, 0.175]);
      if(app.activeDocument.metadataPreferences.documentTitle == 'Beer Steins'){
          var myRectangle = myPage.rectangles.add({strokeWeight:0, geometricBounds:[0, 0, 3, 3.75]});
      myRectangle.place(File('PlaceHolderBeerStein.ai'));
      myRectangle.rotationAngle = -90;
      myRectangle.move([3.5208, 0.1319]);
      myRectangle.move([7.1979, 0.1319]);
      myRectangle.move([10.875, 0.1319]);
      myRectangle.move([3.5208, 4.625]);
      myRectangle.move([7.1979, 4.625]);
      myRectangle.move([10.875, 4.625]);
      if(app.activeDocument.metadataPreferences.documentTitle == 'Can Coolers'){
          var myRectangle = myPage.rectangles.add({strokeWeight:0, geometricBounds:[0, 0, 8.5, 11]});
      myRectangle.place(File('PlaceHolderCanCooler.ai'));
      if(app.activeDocument.metadataPreferences.documentTitle == 'Coffee Mugs Wrap'){
      myRectangle.move([0.125, 0]);
      myRectangle.move([8.1875, 8.5]);
      myRectangle.move([13.875, 8.5]);
          menuItem2Handler = function( /*onInvoke*/ ){
             //LabelGraphics.jsx
      //An InDesign CS4 JavaScript
      @@@BUILDINFO@@@ "LabelGraphics.jsx" 2.0.0 10-January-2008
      //Adds labels to the graphics in the active document.
      //For more on InDesign scripting, go to http://www.adobe.com/products/indesign/scripting/index.html
      //or visit the InDesign Scripting User to User forum at http://www.adobeforums.com
      main();
      function main(){
          //Make certain that user interaction (display of dialogs, etc.) is turned on.
          app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
          if(app.documents.length != 0){
              if(app.documents.item(0).allGraphics.length != 0){
                      myAddLabels();
              else{
                  alert("Document contains no graphics.");
          else{
              alert("Please open a document and try again.");
      function myAddLabels(myLabelHeight, myLabelOffset){
          var myDocument = app.documents.item(0);
          var myGraphics = myDocument.allGraphics;
          var myLabelStyle;
          var layers = app.activeDocument.layers.everyItem().getElements();
          for(var i=layers.length-1;i>=0;i--){
              if(app.activeDocument.layers[i].name == "labels"){
                  layers[i].remove();
              for(var myCounter = 0; myCounter < myGraphics.length; myCounter++){
                  smallSigns(myDocument, myGraphics[myCounter], myLabelHeight, myLabelOffset, myLabelStyle);
                  smallClocks(myDocument, myGraphics[myCounter], myLabelHeight, myLabelOffset, myLabelStyle);
                  largeClocks(myDocument, myGraphics[myCounter], myLabelHeight, myLabelOffset, myLabelStyle);
                  plaques(myDocument, myGraphics[myCounter], myLabelHeight, myLabelOffset, myLabelStyle);
                  largeSigns(myDocument, myGraphics[myCounter], myLabelHeight, myLabelOffset, myLabelStyle);
                  beerSteins(myDocument, myGraphics[myCounter], myLabelHeight, myLabelOffset, myLabelStyle);
                  canCoolers(myDocument, myGraphics[myCounter], myLabelHeight, myLabelOffset, myLabelStyle);
          if(app.activeDocument.metadataPreferences.documentTitle == 'Coffee Mugs Wrap' || app.activeDocument.metadataPreferences.documentTitle == 'Coffee Mugs NoWrap'){
                  coffeeMugs(myDocument, myGraphics[myCounter], myLabelHeight, myLabelOffset, myLabelStyle);
          app.activeDocument.layers.item("labels").locked ^= 1;
      function smallSigns(myDocument, myGraphic){
          myDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
          myDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
          var myLabel;
          var myLink = myGraphic.itemLink;
          //Create the label layer if it does not already exist.
          var myLabelLayer = myDocument.layers.item("labels");
          try{
               myLabelLayer.name;
           catch (myError){
                myLabelLayer = myDocument.layers.add({name:"labels"});
          var myLabel = myLink.linkXmp.description;
          var myFrame = myGraphic.parent;
          var myLabelStyle = myDocument.paragraphStyles.item(2);
          var myLabelHeight = 24;
          myRotation = 0;
          myX1 = myFrame.geometricBounds[1];
          myY1 = myFrame.geometricBounds[2] + 14;
          myX2 = myFrame.geometricBounds[3];
          myY2 = myY1 + 24;
          var myTextFrame = myFrame.parent.textFrames.add(myLabelLayer, undefined, undefined,{rotationAngle:myRotation,geometricBounds:[myY1, myX1, myY2, myX2], contents:myLabel,});
          myTextFrame.textFramePreferences.firstBaselineOffset = FirstBaseline.leadingOffset;
          myTextFrame.parentStory.texts.item(0).appliedParagraphStyle = myLabelStyle;
          app.activeWindow.transformReferencePoint = AnchorPoint.CENTER_ANCHOR;
          myTextFrame.flipItem(Flip.HORIZONTAL);
          if((myGraphic.geometricBounds[3] > myFrame.geometricBounds[3]) || (myGraphic.horizontalScale < 85)){
              if(myFrame.locked == 1){
                  myFrame.locked = 0;
              myGraphic.rotationAngle = 90;
              myGraphic.fit(FitOptions.CONTENT_TO_FRAME);
              if(myFrame.locked == 0){
                  myFrame.locked ^= 1;
          if(myGraphic.horizontalScale > 120){
                  myFrame.locked = 0;
              myGraphic.rotationAngle = 0;
      function smallClocks(myDocument, myGraphic){
          var myLabel;
          try{
               myLabelLayer.name;
           catch (myError){
          myRotation = 0;
          myY1 = myFrame.geometricBounds[2] + 15;
          if(myY1 > 400){
              myY1 = (myFrame.geometricBounds[0] - myLabelHeight - 15);
          myY2 = myY1 + myLabelHeight;
      function largeClocks(myDocument, myGraphic){
          var myLabel;
          try{
               myLabelLayer.name;
           catch (myError){
          myRotation = 0;
          myY1 = myFrame.geometricBounds[2] + 20;
      function plaques(myDocument, myGraphic){
          var myLabel;
          try{
               myLabelLayer.name;
           catch (myError){
          myRotation = 90;
          myX1 = 37;
          myY1 = myFrame.geometricBounds[2];
          myX2 = 200;
          myY2 = myY1 + 50;
          app.activeWindow.transformReferencePoint = AnchorPoint.TOP_LEFT_ANCHOR;
          myTextFrame.flipItem(Flip.VERTICAL);
      function largeSigns(myDocument, myGraphic){
          var myLabel;
          try{
               myLabelLayer.name;
           catch (myError){
          myRotation = 0;
          if((myFrame.geometricBounds[3] + myFrame.geometricBounds[1] > 860) && (myFrame.geometricBounds[0] + myFrame.geometricBounds[2] > 570)){
              myRotation = -90;
              myX1 = myFrame.geometricBounds[0] + 32.25;
              myX2 = myFrame.geometricBounds[2] + 32.25;
              myY1 = myFrame.geometricBounds[1] - 53.75;
          if(myGraphic.geometricBounds[2] > myFrame.geometricBounds[2]){
                  myFrame.locked = 0;
              myGraphic.rotationAngle = -90;
          if(myGraphic.horizontalScale < 70){
                  myFrame.locked = 0;
      function beerSteins(myDocument, myGraphic){
          var myLabel;
          try{
               myLabelLayer.name;
           catch (myError){
          var myLabelHeight = 28.498;
          var offset = 3;
          myRotation = 0;
          myX1 = myFrame.geometricBounds[3] + 54;
          myY1 = myFrame.geometricBounds[0];
          if(myY1 > 350){
              myY1 = (myFrame.geometricBounds[0] - myLabelHeight - offset);
              myRotation = 180;
          myX2 = myFrame.geometricBounds[1];
          myTextFrame.rotationAngle = -90;
      function canCoolers(myDocument, myGraphic){
          var myLabel;
          try{
               myLabelLayer.name;
           catch (myError){
          myRotation = 0;
          myX1 = 480;
          myY1 = 467;
          myX2 = 697;
          myY2 = 491;
      function coffeeMugs(myDocument, myGraphic){
          var myLabel;
          try{
               myLabelLayer.name;
           catch (myError){
          var offset = 5;
          myRotation = 0;
          myY1 = myFrame.geometricBounds[2] + offset;
          if(myY1 > 350){
              myRotation = 180;
      function myGetParagraphStyleNames(){
          var myStyleNames = app.documents.item(0).paragraphStyles.everyItem().name;
          return myStyleNames;
          menuItem3Handler = function( /*onInvoke*/ ){
              var placeAction = app.menuActions.item("$ID/Place...");
              placeAction.invoke();
          menuItem4Handler = function( /*onInvoke*/ ){
              var printAction = app.menuActions.item("$ID/Print...");
              printAction.invoke();
          subMenuItem1Handler = function( /*onInvoke*/ ){
              app.doScript( File(myFolder + 'File-Three.jsx') );
          subMenuItem2Handler = function( /*onInvoke*/ ){
              app.doScript( File(myFolder + 'File-Four.jsx') );
          // SET GENERAL VARIABLES
          try {
              myFolder = app.activeScript;
          catch(e) {
              myFolder = File(e.fileName);  // we are running from the ESTK
          myFolder = myFolder.parent.parent  + '/' ;  //this file is in the "startup scripts" subfolder
          var menuItem1T = "Add Page",
             menuItem2T = "Add Labels",
             menuItem3T = "Place...  Ctrl+D",
             menuItem4T = "Print... Ctrl+P",
             subMenuItem1T = "My SubMenu Item 1",
             subMenuItem2T = "My SubMenu Item 2",
             menuT = "Sublimation",
             subT = "Sub Menu",
             subs = app.menus.item("$ID/Main").submenus, mnu;
          var refItem = app.menus.item("$ID/Main").submenus.item("$ID/&Layout");
          // CREATE MENU ITEMS
          subMenu1 = app.scriptMenuActions.item(menuItem1T);
          if( subMenu1 == null ) {
              subMenu1 = app.scriptMenuActions.add(menuItem1T);
          subMenu1.eventListeners.add("onInvoke", menuItem1Handler);
          subMenu2 = app.scriptMenuActions.item(menuItem2T);
          if( subMenu2 == null ) {
              subMenu2 = app.scriptMenuActions.add(menuItem2T);
          subMenu2.eventListeners.add("onInvoke", menuItem2Handler);
          subMenu3 = app.scriptMenuActions.item(menuItem3T);
          if( subMenu3 == null ) {
              subMenu3 = app.scriptMenuActions.add(menuItem3T);
          subMenu3.eventListeners.add("onInvoke", menuItem3Handler);
          subMenu4 = app.scriptMenuActions.item(menuItem4T);
          if( subMenu4 == null ) {
              subMenu4 = app.scriptMenuActions.add(menuItem4T);
          subMenu4.eventListeners.add("onInvoke", menuItem4Handler);
          subSubMenu1 = app.scriptMenuActions.item(subMenuItem1T);
          if( subSubMenu1 == null ) {
              subSubMenu1 = app.scriptMenuActions.add(subMenuItem1T);
          subSubMenu1.eventListeners.add("onInvoke", subMenuItem1Handler);
          subSubMenu2 = app.scriptMenuActions.item(subMenuItem2T);
          if( subSubMenu2 == null ) {
              subSubMenu2 = app.scriptMenuActions.add(subMenuItem2T);
          subSubMenu2.eventListeners.add("onInvoke", subMenuItem2Handler);
          mnu = subs.item(menuT);
          if( mnu == null ) {
              mnu = subs.add(menuT, LocationOptions.after, refItem);
          subsSubs = app.menus.item( '$ID/Main' ).submenus.item( menuT ).submenus;
          mnu.menuItems.add(subMenu1);
          mnu.menuSeparators.add;
          mnu.menuItems.add(subMenu2);
          mnu.menuItems.add(subMenu3);
          mnu.menuItems.add(subMenu4);
      Any help is much appreciated!
