1 Reply Latest reply on Jun 23, 2006 3:04 PM by Newsgroup_User
    Tv Broadcast within Director
    toby397
      Hello there
      I'm part of a small team that have been commisioned to create an in-house information system for a loca lcompany. Basically, the client wants to be able to display Sky Tv through a plasma monitor via director. Director needs to be used as there will be company information displayed in a scroll bar running over the top of the tv images.
      can anyone suggest a technique or Xtra that would enable us to do this?
      Many thanks...
      Toby Lawrence
        • 1. Re: Tv Broadcast within Director
          Level 7
          Toby,
          Something to look at would be the twain xtra or an xtra that supports twain.
          It sounds like the twain xtra does!
          Then get a twain complaint TV-video input card for the pc. Then you should
          be able to tell the xtra to use the feed from the TV video input and drag
          the sprite on stage. A while back I was using an extra from penworks.com to
          capture video input and noticed that I was able to select my wintv card and
          have it show the tv. But penworks.com is no longer coming up.
          Basically you need to find a combination of a TV input card, possibly even
          USB, and an xtra that will access it.
          webcamxtra will allow you to show video on screen from a webcam. It might
          also allow you to select a TV input signal it it's coming in through
          whatever input it's using which is probabably twain.
          Timm
          "toby397" <webforumsuser@macromedia.com> wrote in message
          news:e7gece$jsh$1@forums.macromedia.com...
          > Hello there
          > able
          > to be
          > running
          > Many thanks...
          > Toby Lawrence
