1 Reply Latest reply on Mar 18, 2014 7:28 PM by A.T. Romano
    Convert PE12 to WVM
      I am new to PE. I read how that I can export to many file types on Adobe Websit, but I cannot find out how to do it. I gone to share, its not there, I gone to File Project save and saveas its not there, I went to Expert mode, but it was not there (there was an export on the file menu grayed out, and it only would export part if it would work). By the youtubes I have watched it seem at least PE9 it could easily be done.
      I got Windows Movie Maker for free and at least it can be saved to a WVM file. Not good quaility, but it does work.
        • 1. Re: Convert PE12 to WVM
          A.T. Romano Level 7
          George T
          Can we assume that you are running Premiere Elements 12 on Windows 7, 8, or 8.1 64 bit computer. I will assume that for now.
          After you set up the Premiere Elements 12 project correctly, there are numerous export choices, export to file saved to the computer hard drive as well as burn to disc (DVD-VIDEO on DVD disc, AVCHD format on DVD disc, and Blu-ray disc format on Blu-ray disc).
          In Premiere Elements 12, the exporting is the section of the program named Publish+Share.
          The choices under Publish+Share are
          Private Web Album
          Social Websites
          Mobile Phones and Players
          You need to explore what is there and what you want to do.
          Let us focus on the Computer choice. Under Computer, you will find
          Adobe Flash Video
          Windows Media
          Many do not see beyond the first three in the Computer list, because they need to use the scroll bar to the right Adobe Flash Video to see the rest in the list. Another to get at the rest of the list without using the scroll bar is to select Adobe Flash Video so that its panel turns blue. Then use the down arrow key to move down the list.
          In Premiere Elements 9.0/9.0.1, the exporting area was named Share. In version 12, it is called Publish+Share. You should have no problems. In 9.0/9.0.1, you had the Timeline view and the Sceneline view. In 12 the counterpart workspaces are Expert and Quick. You can be working in either of these or Guided Expert or Guided Quick. Try to stay with the Expert workspace since I believe you will see better what you are doing and thus have more control over your projects.
          Some reading material for you:
          Premiere Elements 12 Help PDF
          Elements Organizer 12 Help PDF
          My Premiere Elements 12 First Look Blog Post
          My Premiere Elements 12 Daily Discoveries Blog Post
          Please do not hesitate to ask questions and ask for clarification.
