1 Reply Latest reply on Jul 7, 2014 10:50 PM by Athaariq
    4.7 actionscript project with two .as files
    ggiannis
      hi,
      Using FB 4.7 to make actionscript project with two .as file: Main.as and GFX.as. There are variable in GFX that Main cannot access. WHat do I need to do to the GFX.as file to make the variables it declares readable by Main.as?
      GReg
        • 1. Re: 4.7 actionscript project with two .as files
          Athaariq Level 1
          Reason 1:
          put public before var . Example: public var foo:Number
          Reason 2:
          the variable that you can't load in Main.as should be inside function GFX() body. Example:
          package {
               import flash.display.MovieClip
               public class GFX
                    public function GFX()
                         public var foo:Number  // Put your variables here that can be load by another class
                    function anotherFunction(parameters:Number) // Another function starts here
                         foo = parameters
          Reason 3:
          In Main.as, put import GFX after package {
