0 Replies Latest reply on Mar 19, 2014 8:51 AM by JeffLambert
    [AS CC] how to toggle between two properties?
    JeffLambert Level 1
      I'm trying to make a script that would toggle the start paragraph properties between anywhere and next column.
      Here's what I have that doesn't work.
      tell application "Adobe InDesign CC"
                tell active document
                          tell paragraphs of selection
                                    if start paragraph is anywhere then
                                              set start paragraph to next column
                                    else
                                              set start paragraph to anywhere
                                    end if
                          end tell
                end tell
      end tell
      It works only if the paragraphs in questions are in the next column state, but not the other way around. I've tried to make a repeat loop, but can't figure out what the proper form is for this property.
      Any help would be appriciated.
      TIA
      Jeff
