1. Re: Very confused with image quality.
jdanek Mar 19, 2014 11:13 AM (in response to The Cycling Viking)Fuzziness could be from the distance from the original, lighting, Fstop, and your hand's slight movement hitting the shutter. I recommend getting a tri-pod and really lighting the sirt up a bit brighter. You do not mention what you are using to photograsph the shirt. That could be another factor.
2. Re: Very confused with image quality.
The Cycling Viking Mar 19, 2014 11:20 AM (in response to jdanek)Hi Jdanek,
apologies, it's not with the quality of the captured images, I only enclosed them as examples as to try to highlight my point.
I'm concerned with the quality of the logos/ images once I've printed them out on to the jersey templates. I'm trying to establish how the quality of the logos on the yellow jersey are so much clearer and cleaner than mine (on the blue jersey).
3. Re: Very confused with image quality.
jdanek Mar 19, 2014 11:42 AM (in response to The Cycling Viking)1 person found this helpfulIt might be anti-aliasing in Photoshop, but I'm not sure what you are asking. I would think a direct export from wherever you create the original, should hold up, especially in a file reduction to a key chain template. It could also be the resolution. I doubt it has anything to do with the printer or the glossy paper.
4. Re: Very confused with image quality.
davetwo Mar 19, 2014 11:53 AM (in response to The Cycling Viking)1 person found this helpfulHi, I imagine the other keyring was produced from vector artwork (using a program like illustrator). Photoshop is really king of 'photographic' images rather than this kind of hard-edge flat-color art. It's possible to create in Photoshop, but you need to be using paths and outputting as pdf.
5. Re: Very confused with image quality.
The Cycling Viking Mar 19, 2014 12:26 PM (in response to jdanek)Thanks for your help :) couple of things to google, especially the anti aliasing :)
6. Re: Very confused with image quality.
The Cycling Viking Mar 19, 2014 12:28 PM (in response to davetwo)Thank you Dave.
It's taken me weeks to get to grips with the very basics of PS. Looks like I need to switch to Illustrator :)
Such a complex world adobe! :)
