0 Replies Latest reply on Mar 19, 2014 11:09 AM by lovestream
    Q's about Find & Replace and keyboard shortcuts
    lovestream
      Hi, I've got 2 questions:
      1. Is it possible - using for instance the Find and Replace funktion - to automatically wrap a span tag around plain text (that has no tags - not even p), that appears in different places in a document?
      Example:
      <h1 class="lyrics">this text should not be changed</h1>
      <span class="akkord">this text should not be changed either</span><br>
      This text should be changed (wrapped)
      2. When I try to assign a keyboard shortcut to Snippets, it doesn't work. When I press Change in the
      keyboard shortcut dialog, the shortcut appears to the right of the specific snippet as expected. But
      when I press Ok, nothing happens when I select some text and use the shortcut key combination.
      When I go back to the keyboard shortcut dialog, the newly assigned shortcut is gone!
      Any suggestions?
