This content has been marked as final.
Show 6 replies
1. Re: Can you organize your "links" panel by FILE TYPE ?
Joel Cherney Mar 20, 2014 11:48 AM (in response to Ceencha)Well, maybe. You can click the dropdown button at the top-right hand corner of the panel, choose "Panel Options" then place a check next to "Format" in the "Show Column" checkbox. Then you can sort your links by file format, which really isn't exactly what you were asking for, but is awfully close.
2. Re: Can you organize your "links" panel by FILE TYPE ?
John Mensinger Mar 20, 2014 11:49 AM (in response to Ceencha) -
3. Re: Can you organize your "links" panel by FILE TYPE ?
Ceencha Mar 20, 2014 12:30 PM (in response to John Mensinger)THANK YOU!!!!!!!
4. Re: Can you organize your "links" panel by FILE TYPE ?
Ceencha Mar 20, 2014 12:34 PM (in response to John Mensinger)Hmmm … it seems to be calling .ai files as "ADOBE PDF" files … why?
5. Re: Can you organize your "links" panel by FILE TYPE ?
John Mensinger Mar 20, 2014 12:50 PM (in response to Ceencha)It's no malfunction. Programmatically, Illustrator files are PDF files.
6. Re: Can you organize your "links" panel by FILE TYPE ?
BobLevine Mar 20, 2014 12:55 PM (in response to Ceencha)Because they are. When you place an AI file, InDesign reads the PDF portion of the file. If you were to save without PDF compatibility you wouldn’t be able to place the file.
