3 Replies Latest reply on Mar 20, 2014 1:06 PM by John Mensinger
    Indesign to PDF with information
    gjohung
      99% of my project will be converted to PDF for review and approval.  I wanted to add to the PDF addtional information such as Size: Client Name, Publication and Output preference. I created a slug area within InDesign. and exported PDF.
      Some publication does not like that. They want PDF as is. No slugs, Crop/Reg marks.
      I could re-open the PDF and go in to properties and add information in the metadata. It can be 2 step process..
      Is there a way that I can insert these information within InDesign so that it will show up in PDF...
      Thanks.
        • 1. Re: Indesign to PDF with information
          John Mensinger Adobe Community Professional & MVP
          Yes, enter it it the File Info dialog; File > File Info or Ctrl/Cmd + Shift + I
          • 2. Re: Indesign to PDF with information
            gjohung Level 1
            Thank..
            Is there a way to View that at first glance in PDF without going through Additional Info tab..
            ghj
            • 3. Re: Indesign to PDF with information
              No. The Document Properties dialog must be called up. I have one idea, but since you were trying to save a step, this may not be ideal...
              When you open a PDF, (in Acrobat, of course), 3 things can be visible:
              1. The document (page + bleed + slug; as you've already explored)
              2. Acrobat's panels; Pages, Bookmarks, Navigation, Attachments
              3. Comments
              So, if there is non-page information you want shown when an Acrobat user opens your PDF, you could add that info to a Comment or "Sticky Note." I haven't tested it exhaustively or anything, but when I add a sticky note, then right-click and choose Open All Popups, then Save...the open popups persist and are visible when I reopen. This would serve your purpose and also stay out of the print workflow.
