2 Replies Latest reply on Mar 20, 2014 12:42 PM by porkbus
    AE CC set custom workspace to default
    porkbus Level 1
      I feel like this used to be an option under workspace, but I can't figure out how.  I would like my custom interface that has been saved to open every time as the default workspace. Is that possible? I'm sure it's probably a simple thing but I can't seem to find the answer.
      Thank you!
        • 1. Re: AE CC set custom workspace to default
          Ae will open with the last workspace that was used, so I'm not sure what you are asking.
          Mylenium
          • 2. Re: AE CC set custom workspace to default
            porkbus Level 1
            thank you mylenium. i just realized after i posted that the project was last opened on my home machine with a single monitor setup. I was opening said project, doing a save as a new version. then reopening that original project. as a part of my workflow.  each time i reopened the original project, i figured out that because i had not made a change to THAT project and done a save, it had not registered/saved the current workspace. i'm probably not making sense, but issue has been solved. thank you for the quick response!
