3 Replies Latest reply on Mar 21, 2014 5:49 AM by JimHess
    RAF converter for Photoshop
    annafg
      I cannot convert my RAF files, taken with my Fujifilm XT 1.  My PC works on WIndows 7.  I use Adobe CS4.  The DNG converter I have installed is 8.4.
      Help!
        • 1. Re: RAF converter for Photoshop
          That converter should work. Take note that when you are looking for the source in the DNG converter you are looking for the folder, not the files. If you open the folder that has your raw images in it the DNG converter will tell you there are no files to convert. Just choose the folder that contains those RAF files and then click the convert button and it should work.
          • 2. Re: RAF converter for Photoshop
            annafg Level 1
            Brilliant!  Thank you very much, Jim, it worked.  I was having
            nightmares & woke up in a sweat over having to learn a Japanese version
            of Photoshop!
            • 3. Re: RAF converter for Photoshop
              I'm glad that worked for you. Just one other little side note. If you only want to convert specific files, you can drag/drop them onto the icon for the DNG converter. The converter will start and will only convert those images. You still need to take care to designate the appropriate destination.
