10 Replies Latest reply: Mar 21, 2014 1:04 AM by Picturequest RSS
    Virtual copies and using Description, or title etc to print
    Picturequest Community Member
      Hi!
      Never really use the text features in LR.
      I've built a strip sheet to print. 4 strips with 4 versions (VIRTUAL COPIES) of the same image with different exposures.
      I remember in the Print Module, you can add text. in this case I'd like to add the exposure (manually is fine) Example:  NORMAL     +1/3      +2/3    +1
      So, this is a virtual copy problem.
      It wont allow me to add the text to DESCRIPTION, Also, Under: Title, I can add say NORMAL, but that is the same for each image. Can't be individually labeled?
      Is there anyway to label, title, description, etc, a series of the same Virtual Copies. Again, it would be great to print the actual exposure, but I'd be happy manually labeling the VC.
      Thank you!
      Max
