3 Replies Latest reply on Mar 21, 2014 12:15 AM by Willi Adelberger
    Indesign and Pagemaker
    myartmind
      We are in the process of ending our license with pagemaker at my job.  However, I haven't had a chance to convert all the pagemaker files to Indesign files.  I want to know if the pagemaker files will open in Indesign after the program has been deleted?
        • 1. Re: Indesign and Pagemaker
          InDesign can open and convert PageMaker files up to CC Version 8.
          If someone is a CC (Creative Cloud) subscriber he has access always to the latest build of each version which is now CC 9.2 but can also install from CS6 8.x the latest build. So if you (or your company) is subscribing to CC they have to install CS6 manually so that your files could be opened.
          The conversion can be very different, so I would strongly recommend to keep one old computer with PM on board, and that you create of each PM file a PDF to compare how it looked like before to adjust the documents after conversion or at least to be aware where things have changed.
          • 2. Re: Indesign and Pagemaker
            myartmind Level 1
            We have Adobe Indesign CS6 (not the cloud version). I used it today to open a pagemaker file and it worked perfectly, however I was unsure that it would work after we uninstall pagemaker 7 from the computer.  Oh and sorry for the late response.
            Blake
            Sent from my iPad
            • 3. Re: Indesign and Pagemaker
              For InDesign you don't need PageMaker to convert files. But for your own security you might keep a copy on an old computer. Not every conversion is perfect, some are less.
