3 Replies Latest reply on Mar 23, 2014 4:52 AM by TRWILSON777
    Spell check Crashes with pongrass publishing systems
    TRWILSON777
      Good Day
      My team uses Pongrass to put our newspaper together,  when ever 1 or 2 users use their spell check it crashes.
      this is the report in the events log.
      Exception code: 0xc0000005
      Fault offset: 0x0018c6dd
      Faulting process id: 0x2ae8
      Faulting application start time: 0x01cf44db5691d74e
      Faulting application path: C:\Program Files (x86)\Adobe\Adobe InDesign CS5.5\InDesign.exe
      Faulting module path: C:\Program Files (x86)\Adobe\Adobe InDesign CS5.5\Required\TEXT.RPLN
      Report Id: bb2b9d41-b0ce-11e3-b275-10604b7df428
      I did try to replace the TEXT.RPLN with one from a working PC, that did not work.
      Does anyone use pongrass? ( it plugs-in Indesign) also when not working in pongrass, just thru indesign CS5 5.5, the spell check still crashes. the removing of preferences does not help.
      Thanks for taking the time
