1. Re: Restore inadvertantly deleted column
Josh_CoreyMar 21, 2014 9:54 AM (in response to egoldstone)
Immediately after it happened using "Ctrl+Z" (Cmd+Z on Mac) should undo your change. Since you've likely done other things now you'll want to restore it by going into the History and copying it into the current view of the Response Table, see this FAQ for more details: http://forums.adobe.com/docs/DOC-4071
Josh
2. Re: Restore inadvertantly deleted column
egoldstone Mar 21, 2014 10:00 AM (in response to Josh_Corey)Thanks Josh,
The "History" feature enabled me to recover my inadvertantly deleted data; HOWEVER, the original data that populated that column was linked to a field in the associated form. When I successfully copied and pasted the contents from the historical archived version into the current live version, the linkage to the form field that originally existed no longer appears to be active. How can I fix this screw-up??? And, in the interim, if someone submits a completed form, what will become of data entered in the field in question?
Thanks for your guidance and for the FormsCentral education!
3. Re: Restore inadvertantly deleted column
Josh_CoreyMar 21, 2014 10:05 AM (in response to egoldstone)
Hi;
You should probably delete the original field from the form and re-create it so that it creates the linked column in the response table, then you can copy the data from the one in History into the linked column rather than inserting the entire column from history. I should probably update that FAQ with a note about this.
Josh
