2 Replies Latest reply on Jun 25, 2006 11:12 AM by Newsgroup_User
    Control with lingo a film loop
    Level 7
      Dear all:
      Do you know how to control a film loop. Stop, pause, rewind and play?
      many thanks
        • 1. Re: Control with lingo a film loop
          James Newton, ACP Level 3
          A filmLoop will play through to the end. I do not know of a way to stop or pause it. You can rewind and replay a filmloop:
            tell sprite("filmLoop") to set the frame = 1
          OR
            member("filmLoop").loop = FALSE -- rewinds the filmLoop as a side-effect
          • 2. Re: Control with lingo a film loop
            Level 7
            This behavior, dropped onto a filmloop sprite, should do it for you:
            --dave@blurredistinction.com
            -- http://www.blurredistinction.com/director
            property isPlaying, strtFrame, curFrame, backwards
            property isLooping, loopTot, curLoop
            on getPropertyDescriptionList
            pList = [:]
            pList.addProp(#isPlaying, [#comment:"Begin play at start:",
            #format:#boolean, #default:true])
            pList.addProp(#backwards, [#comment:"Play backwards:", #format:#boolean,
            #default:false])
            pList.addProp(#isLooping, [#comment:"Loop play:", #format:#boolean,
            #default:true])
            pList.addProp(#loopTot, [#comment:"Loop x times (0 for forever):",
            #format:#integer, #default:0])
            return pList
            end
            on beginSprite me
            tell sprite(me.spriteNum)
            curFrame = the frame
            strtFrame = curFrame
            end tell
            curLoop = 0
            end
            on exitFrame me
            if not isPlaying then
            tell sprite(me.spriteNum) to go curFrame
            else
            if backwards then
            prevFrame(me)
            else
            nextFrame(me)
            end if
            end if
            end
            on nextFrame me
            curFrame = curFrame + 1
            if curFrame > the lastFrame then
            curFrame = strtFrame
            curLoop = curLoop + 1
            if isLooping then
            if curLoop = loopTot then
            isPlaying = 0
            end if
            else
            isPlaying = 0
            end if
            end if
            go curFrame
            end tell
            end
            on prevFrame me
            curFrame = curFrame - 1
            if curFrame < strtFrame then
            curFrame = the lastFrame
            if isLooping then
            if curLoop = loopTot + 1 then
            isPlaying = 0
            end if
            else
            isPlaying = 0
            end if
            end if
            go curFrame
            end tell
            end
            on pausePlay me
            ispLaying = 0
            end
            on playNormal me
            isPlaying = 1
            backwards = 0
            end
            on playBackwards me
            isPlaying = 1
            backwards = 1
            end
            Then you can do:
            sprite(x).playBackwards()
            sprite(x).playNormal()
            sprite(x).pausePlay()
            HTH
            Dave -
            Adobe Community Expert
            http://www.adobe.com/communities/experts/
