7 Replies Latest reply on Mar 24, 2014 6:35 AM by kglad
    Using strings to go to other scenes
    zoner9
      Hi, I'm having a bit of a problem:
      I'm trying to use an input text field as a cheat code input to move between 2 different scenes - if the code is correct, I want to go to one scene, but if the code is not correct, I want to go to a different scene. At the moment, no matter what I put into the text field, I end up going to the scene that's supposed to be for incorrect codes - even when I enter the correct code.
      The code I'm using:
      stop();
      //stops on this scene
      var cheat:String = "Enter Code Here";
      //declaring a variable for a cheat code
      _root.cheatBox.cheat = cheat;
      //sets the text of the cheat box to cheat
      _root.menuButton.onRelease = function()
      //when the menu button is released
        gotoAndStop("Menu", 1);
        //goes to menu scene and stops on that scene
      _root.cheatBox.goButton.onRelease = function()
      //when the go button in the cheat box is released
        if(_root.cheatBox.cheat == "N0496151")
        //if the text box contains the code
         gotoAndStop("Cheat", 1);
         //goes to the cheat scene and stops on that scene
        else if(_root.cheatBoxcheat != "N0496151")
        //otherwise
         //goes to the menu scene and stops on that scene
      All of this code is on the main timeline, is there something I'm not doing right?
