10 Replies Latest reply on Apr 1, 2014 5:00 PM by A.T. Romano
    Premiere elements 9 préconfiguration youtube
    christiandu13
      Bonjour. Ma question concerne premiere elements 9. Je suis sous W7 familial. Suite à des blocages soudains de premiere elements 9 j'ai désinstallé puis réinstallé ce logiciel. Mais je ne peux plus poster de vidéo sur Youtube, la préconfiguration ne s'est pas installée.
      Pouvez vous m'indiquer la marche à suivre pour installer cette préconfiguration Youtube.
      Par avance , merci.
        • 1. Re: Premiere elements 9 préconfiguration youtube
          A.T. Romano Level 7
          christiandu13
          For several days/weeks, there has been YouTube "Online Services" failure with the upload to YouTube from within Premiere Elements. It has affected at least Premiere Elements 9.0/9.0.1, 10, 11, and 12. We must wait for YouTube and/or Adobe to correct the problem. While YouTube is failing, Vimeo is working.
          Until the problem is resolved by the parties involved, please consider exporting your Timeline to a file saved to the computer hard drive and then uploading that file from there to YouTube at the YouTube web site.
          For version 9.0/9.0.1, you might consider one of the QuickTime choices for the file to be uploaded to YouTube at the YouTube web site. Or, you could trying using the Vimeo upload from within Premiere Elements 9.0/9.0.1. The file that I would prefer in your case would be a H.264.mp4 from the Mobile Phones and Player export categories.
          We are not Adobe. Just user to user. So, we have no insider information on what is going on in this situation.
          You will no doubt get your YouTube preset back once the problem is resolved and you reinstall Premiere Elements 9.0/9.0.1.
          Thank you.
          ATR
          • 2. Re: Premiere elements 9 préconfiguration youtube
            nealeh Level 5
            YouTube sharing is now working again.
            Cheers,
            Neale
            If this post or another user's post resolves the original issue, please mark the posts as correct and/or helpful accordingly. This helps other users with similar trouble get answers to their questions quicker. Thanks.
            • 3. Re: Premiere elements 9 préconfiguration youtube
              the_wine_snob Level 9
              Neale,
              That is good to know, and thank you for reporting.
              • 4. Re: Premiere elements 9 préconfiguration youtube
                A.T. Romano Level 7
                christiandu13
                Earlier today the Online Services issue is gone from upload to YouTube from within Premiere Elements 9.0/9.0.1. I tested this with version 9.0/9.0.1 as well as with versions 10, 11, and 12. All is working for the Premiere Elements feature with my versions of Premiere Elements.
                If you encounter any more issues with your Premiere Elements 9.0/9.0.1 Share/Online/YouTube, please let us know no matter what the error message.
                Hope all is working there for this Premiere Elements feature.
                Please let us know the outcome when you get the time.
                Thank you.
                ATR
                • 5. Re: Premiere elements 9 préconfiguration youtube
                  christiandu13 Level 1
                  Bonjour,
                  J'ai fait MODIFIER/PREFERENCE/PARTAGEWEB/ACTUALISER.
                  Puis j'ai enregistré le projet, fermé Premiere elements 9, lancé un nouveau projet.
                  Mais malgré cela je n'ai toujours aucune préconfiguration proposée !
                  Pouvez vous m'indiquer comment réparer cela ? Ya t'il moyen de télécharger seulement un module ou dois je réinstaller tout Premiere elements 9 ? Est ce que vous avez un lien pour télécharger Premiere Elements 9 sur internet ?
                  Merci de votre réponse.
                  • 6. Re: Premiere elements 9 préconfiguration youtube
                    A.T. Romano Level 7
                    crhistiandu13
                    You can download Premiere Elements 9 installation files from the following link and then insert your purchased serial number during installation of them.
                    http://prodesigntools.com/photoshop-elements-9-premiere-elements-9-direct-download-links.h tml
                    But you need to read the "Note: Very Important Instruction" very carefully, otherwise you will run into Access Denied message.
                    You should have no problems with Share/Online/YouTube after the installation...all the presets should be downloaded automatically to the Share/Online/YouTube.
                    Please let us know the outcome.
                    Thank you.
                    ATR
                    • 7. Re: Premiere elements 9 préconfiguration youtube
                      Bonjour,
                      Voilà, j'ai désinstallé puis réinstallé Premiere 9.
                      J'ai récupéré la préconfiguration Youtube et le téléchargement fonctionne bien.
                      Mais un autre problème est apparu :
                      MPEG2 1440 X 1080i 25, MPEG2 1440 X 1080i 30, MPEG2 1920 X 1080i 25 et
                      MPEG2 1920 X 1080i 30 n'est plus possible !!!!
                      Or pour avoir la meilleure qualité j'utilise le plus souvent MPEG2 1920 X 1080i 30.
                      Pouvez vous m'aider à restaurer cette fonction ?
                      • 8. Re: Premiere elements 9 préconfiguration youtube
                        A.T. Romano Level 7
                        christiandu13
                        Yes, we have an answer for you about your missing MPEG2 presets. This is an old Premiere Elements 9.0/9.0.1 story. Here is an excerpt from my Premiere Elements 9 Daily Discovery thread (date November 28, 2010)
                          PE9: Download for H.264 Presets Missing From MPEG Preset List
                          poissony was the first to report
                        "Missing AVCHD Export Presets In Premiere Elements 9"
                        http://www.elementsvillage.com/forum...ad.php?t=61459
                        Unfortunately, no explanation nor solution was found.
                        namefunnel more recently ran into the same problem.
                        (see poissony's thread)
                        A B has pointed us to an Adobe document for resolution of the issue.
                        Please see
                        "H.264 presets missing from MPEG preset list in Premiere Elements 9 (Windows)"
                        http://kb2.adobe.com/cps/882/cpsid_88202.html
                        where a download of the missing files is provided plus instruction for their installation in the Premiere Elements 9 program files.
                        ATR
                        The details for the download for the missing MPEG2 presets are in the document pointed to by A B
                        http://helpx.adobe.com/premiere-elements/kb/h-264-presets-missing-mpeg.html
                        Please let us know if that worked for you.
                        Thank you.
                        ATR
                        • 9. Re: Premiere elements 9 préconfiguration youtube
                          Tout marche !
                          Merci beaucoup de votre aide
                          • 10. Re: Premiere elements 9 préconfiguration youtube
                            A.T. Romano Level 7
                            christiandu13
                            Such wonderful news "Everything works!"
                            Finding the answer in 2010 for the missing Premiere Elements 9 MPEG 2 presets was a puzzle until A B (Adobe Staff) helped with the answer and the download for the missing files.
                            Best wishes with your Premiere Elements projects,
                            ATR
