Thanks for the template suggestion, however, as I stated
earlier, when I use the template file, save as a new file &
start recording new slides the new files are recorded at the
"default" settings. For example, in the template, all slide Quality
is set to "Standard", and for textboxes all fonts are set to 14 pt,
and transition is set to "no transition", highlight boxes are set
to "no transition", etc. After recording, new slides are High
Quality, textboxes & highlight boxes are Fade in/Fade out, and
fonts are 12 point. My question is - Is there a way to reset the
"default" recording setting for slide quality, textbox transition,
font size, etc. I don't see or cannot find a way to do that. If
there isn't a way to change defaults without having to do it a code
level, then that's fine, however, I would like to know that.
