9 Replies Latest reply on Mar 27, 2014 1:23 PM by Todd_Kopriva
    gpu
    junction 21 Level 1
      why dose after effects say my card is not comapatable or the drivers are out of date
      the nvidia gtx 780 is aproved  and the driver is upto date
      what do i need to do to use the gpu
      can any one advise  please
        • 1. Re: gpu
          What exact version of After Effects are you using?
          What is your driver number?
          What is the CUDA driver number?
          Where are you seeing After Effects telling you that it's not compatible?
          What are your system specs?
          What are you using the GPU for? Unless you're using the (outdated) ray-traced 3d renderer or some third-party plugin, AE doesn't really use the GPU at all. See this.
          • 2. Re: gpu
            junction 21 Level 1
            ae ver11.0.4.2
            edit preferences  previews gpu info
            gpu not avaqilable  incompatable device or display driver
            driver ver 335.23
            win 7 proff
            16gig ram
            17 processor
            how do i find cuda driver number
            i am not using gpu for any purpose i just wondered why it was not available
            • 3. Re: gpu
              Todd_Kopriva Level 8
              Where do you see information telling you that for your version of After Effects?
              • 4. Re: gpu
                junction 21 Level 1
                also the mercury playback engin in prem pro  is greyed out
                all the aproved gtx cards listed on adobe web site are old and out of date nvidia
                gtx 780 is not listed
                • 5. Re: gpu
                  The GTX 780 is listed for After Effects CC.
                  You say that the list is out of date, but consider that you're asking about an older version of After Effects, After Effects CS6.
                  • 6. Re: gpu
                    junction 21 Level 1
                    i have just had new computer built i check adobes site for the approved video card nivida gtx 780 was lised as ok in the spec list
                    but i have now found out it will not work for mercury play back engin in prem pro
                    or gpu acceleration in after effects can you explain why  and what ican do to make itwork
                    i ask on thr pp forums all i got was alink to hack the insilation files in pp surley that can not be right
                    ps i am using cs6
                    • 7. Re: gpu
                      No, that is not correct. Give me the link to the page that you say lists this card as approved for the CS6 version of the software.
                      That GPU is not supported for the version of After Effects that you are using. It is supported for After Effects CC. Same for Premiere Pro CC. Not CS6.
                      I will not assist you in hacking anything.
                      • 8. Re: gpu
                        junction 21 Level 1
                        i do not want to hack the program  that was the advice i was give from the pp forums
                        will  nvida gtx780 be approved for use with cs6
                        • 9. Re: gpu
                          If someone is giving you advice, then ask them.
                          I will not be assisting you in an unsupported task.
                          No.
