5 Replies Latest reply on Mar 26, 2014 2:37 PM by rickhawaii
    Why does the Panorama feature in Photoshop CC crash?
    rickhawaii
      Why does the panorama feature is Photoshop CC crash?  Works OK in Photoshop CS6.
        • 1. Re: Why does the Panorama feature in Photoshop CC crash?
          It would be helpful if you would post the information in the crash report and your system information. Use Photoshop menu Help>System Info... the use copy and past  the information into an append.  Also any crash information you system has recorded. if your using windows use windows reliability History the find the Photoshop Crash information.
          • 2. Re: Why does the Panorama feature in Photoshop CC crash?
            rickhawaii Level 1
            Adobe Photoshop Version: 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00) x64
            Operating System: Mac OS 10.8.5
            System architecture: Intel CPU Family:6, Model:30, Stepping:5 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
            Physical processor count: 4
            Logical processor count: 8
            Processor speed: 2930 MHz
            Built-in memory: 8192 MB
            Free memory: 5013 MB
            Memory available to Photoshop: 7532 MB
            Memory used by Photoshop: 70 %
            Image tile size: 128K
            Image cache levels: 1
            Font Preview: Medium
            TextComposer: Latin
            Display: 1
            Main Display
            Display Bounds: top=0, left=0, bottom=1440, right=2560
            OpenGL Drawing: Enabled.
            OpenGL Allow Old GPUs: Not Detected.
            OpenGL Drawing Mode: Advanced
            OpenGL Allow Normal Mode: True.
            OpenGL Allow Advanced Mode: True.
            AIFCoreInitialized=1
            AIFOGLInitialized=1
            OGLContextCreated=1
            NumGPUs=1
            gpu[0].OGLVersion="2.1"
            gpu[0].MemoryMB=1024
            gpu[0].RectTextureSize=16384
            gpu[0].Renderer="ATI Radeon HD 5750 OpenGL Engine"
            gpu[0].RendererID=16915202
            gpu[0].Vendor="ATI Technologies Inc."
            gpu[0].VendorID=4098
            gpu[0].HasNPOTSupport=1
            gpu[0].CompileProgramGLSL=1
            gpu[0].TestFrameBuffer=1
            gpu[0].OCLPresent=1
            gpu[0].OCLVersion="1.2 (Apr 25 2013 18:32:06)"
            gpu[0].CUDASupported=0
            gpu[0].OCLBandwidth=1.3646e+10
            gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
            gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[4096]
            gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
            gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
            gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
            gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
            gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
            gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
            gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
            gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
            gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
            gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
            gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
            gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
            gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
            gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
            gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
            gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
            gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
            gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
            gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
            License Type: Subscription
            Serial number: 96040253788964359019
            Application folder: /Applications/Adobe Photoshop CC/
            Photoshop scratch has async I/O enabled
            Scratch volume(s):
              Startup, 930.4G, 431.1G free
            Required Plug-ins folder: /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/Required/Plug-Ins/
            Primary Plug-ins folder: /Applications/Adobe Photoshop CC/Plug-ins/
            Installed components:
               adbeape.framework   adbeape   3.4.0.29366   0.1160850
               AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.3.2.31983   79.546835
               adobe_caps.framework   adobe_caps   7.0.0.21   1.248010
               AdobeACE.framework   AdobeACE   2.20.02.31977   79.548223
               AdobeAGM.framework   AdobeAGM   4.30.29.31977   79.548223
               AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
               AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
               AdobeBIB.framework   AdobeBIB   1.2.03.31977   79.548223
               AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.548223
               AdobeCoolType.framework   AdobeCoolType   5.15.00.31977   79.548223
               AdobeCrashReporter.framework   AdobeCrashReporter   7.0.1
               AdobeExtendScript.framework   AdobeExtendScript   4.5.5.31983   79.546835
               AdobeJP2K.framework   AdobeJP2K   1.2.2.31977   79.248139
               AdobeLinguistic.framework      19061
               AdobeMPS.framework   AdobeMPS   5.8.1.31977   79.535029
               AdobeOwl.framework   AdobeOwl   5.0.24   79.547804
               AdobePDFL.framework   AdobePDFL   11.0.0.31977   79.508720
               AdobePDFSettings.framework   AdobePDFSettings   1.4
               AdobePIP.framework   AdobePIP   7.0.0.1786
               AdobeScCore.framework   AdobeScCore   4.5.5.31983   79.546835
               AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
               AdobeXMP.framework   AdobeXMPCore   79.154911   79.154911
               AdobeXMPFiles.framework   AdobeXMPFiles   79.154911   79.154911
               AdobeXMPScript.framework   AdobeXMPScript   79.154911   79.154911
               ahclient.framework   ahclient   1.8.0.31
               aif_core.framework   AdobeAIF   5.0.00   79.534508
               aif_ocl.framework   AdobeAIF   5.0.00   79.534508
               aif_ogl.framework   AdobeAIF   5.0.00   79.534508
               AlignmentLib.framework   xcode   Copyright © 2013 Adobe Systems Incorporated
               amtlib.framework   amtlib   7.0.0.249
               boost_date_time.framework   boost_date_time   7.0.0.0
               boost_signals.framework   boost_signals   7.0.0.0
               boost_system.framework   boost_system   7.0.0.0
               boost_threads.framework   boost_threads   7.0.0.0
               Cg.framework   NVIDIA Cg
               CIT.framework   CIT   2.1.6.30929   151865
               CITThreading.framework   CITThreading   2.1.6.30929   151865
               dvaaudiodevice.framework   dvaaudiodevice   7.0.0.0
               dvacore.framework   dvacore   7.0.0.0
               dvamarshal.framework   dvamarshal   7.0.0.0
               dvamediatypes.framework   dvamediatypes   7.0.0.0
               dvaplayer.framework   dvaplayer   7.0.0.0
               dvatransport.framework   dvatransport   7.0.0.0
               dvaunittesting.framework   dvaunittesting   7.0.0.0
               dynamiclink.framework   dynamiclink   7.0.0.0
               FileInfo.framework   FileInfo   79.154511   79.154511
               filter_graph.framework   AdobeAIF   5.0.00   79.534508
               ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
               ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
               LogSession.framework   LogSession   2.1.2.1785
               mediacoreif.framework   mediacoreif   7.0.0.0
               patchmatch.framework   patchmatch   1.2.00.31977   79.542390
               PlugPlugOwl.framework   PlugPlugOwl   4.2.0.36
               UpdaterNotifications.framework   UpdaterNotifications   7.0.1.102   "7.0.1.102"
               WRServices.framework
            Required plug-ins:
               3D Studio 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
               Accented Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Adaptive Wide Angle 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
               Angled Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Average 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Average.plugin”
               Bas Relief 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               BMP 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Camera Raw 8.3 (141), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
               Camera Raw Filter 8.3 (141), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
               Chalk & Charcoal 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Chrome 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Cineon 14.2.1 x001  ©2002-2014 Adobe Systems Incorporated - from the file “Cineon.plugin”
               Clouds 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
               Collada DAE 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
               Color Halftone 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Colored Pencil 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               CompuServe GIF 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Conté Crayon 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Craquelure 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Crop and Straighten Photos 14.2.1 x001  ©2003-2014 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
               Crop and Straighten Photos Filter 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Crosshatch 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Crystallize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Cutout 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Dark Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               De-Interlace 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Dicom 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “dicom.plugin”
               Difference Clouds 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
               Diffuse Glow 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Displace 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Dry Brush 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Eazel Acquire 14.2.1 x001  ©1997-2014 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
               Embed Watermark NO VERSION - from the file “DigiSign.plugin”
               Entropy 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
               Extrude 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               FastCore Routines 14.2.1 x001  ©1990-2014 Adobe Systems Incorporated - from the file “FastCore.plugin”
               Fibers 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Film Grain 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Filter Gallery 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Flash 3D 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
               Fresco 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Glass 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Glowing Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Google Earth 4 KMZ 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
               Graphic Pen 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Halftone Pattern 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               HDRMergeUI 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
               IFF Format 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Ink Outlines 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               JPEG 2000 14.2.1 x001  ©2001-2014 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
               Kurtosis 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
               Lens Blur 14.2, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
               Lens Correction 14.2, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
               Lens Flare 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Liquify 14.2, Copyright © 2001-2014 Adobe Systems Incorporated - from the file “Liquify.plugin”
               Matlab Operation 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
               Maximum 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
               Mean 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
               Measurement Core 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
               Median 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
               Mezzotint 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Minimum 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
               MMXCore Routines 14.2.1 x001  ©1990-2014 Adobe Systems Incorporated - from the file “MMXCore.plugin”
               Mosaic Tiles 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Multiprocessor Support 14.2.1 x001  ©1990-2014 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
               Neon Glow 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Note Paper 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               NTSC Colors 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
               Ocean Ripple 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Oil Paint 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
               OpenEXR 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Paint Daubs 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Palette Knife 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Patchwork 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Paths to Illustrator 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               PCX 14.2.1 x001  ©1989-2014 Adobe Systems Incorporated - from the file “PCX.plugin”
               Photocopy 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Photoshop 3D Engine 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
               Photoshop Touch CC (14.2.0.0) ©1993-2014 Adobe Systems Incorporated - from the file “PSDX.plugin”
               Picture Package Filter 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
               Pinch 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Pixar 14.2.1 x001  ©1989-2014 Adobe Systems Incorporated - from the file “Pixar.plugin”
               Plaster 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Plastic Wrap 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               PNG 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Pointillize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Polar Coordinates 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Portable Bit Map 14.2.1 x001  ©1989-2014 Adobe Systems Incorporated - from the file “PBM.plugin”
               Poster Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Radial Blur 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Radiance 14.2.1 x001  ©2003-2014 Adobe Systems Incorporated - from the file “Radiance.plugin”
               Range 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
               Read Watermark NO VERSION - from the file “DigiRead.plugin”
               Reticulation 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Ripple 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Rough Pastels 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Save for Web 14.2, Copyright © 1999-2014 Adobe Systems Incorporated - from the file “Save for Web.plugin”
               ScriptingSupport 14.2.1, Copyright © 2014 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
               Shake Reduction 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
               Shear 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Skewness 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
               Smart Blur 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Smudge Stick 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Solarize 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Solarize.plugin”
               Spatter 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Spherize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Sponge 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Sprayed Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Stained Glass 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Stamp 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Standard Deviation 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
               STL 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
               Sumi-e 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Summation 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
               Targa 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Texturizer 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Tiles 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Torn Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Twirl 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Underpainting 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Vanishing Point 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
               Variance 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
               Water Paper 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Watercolor 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Wave 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Wavefront|OBJ 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
               Wind 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Wireless Bitmap 14.2.1 x001  ©1989-2014 Adobe Systems Incorporated - from the file “WBMP.plugin”
               ZigZag 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
            Optional and third party plug-ins:
               BackgroundFilter 2.200, Copyright © 2003-2012 Google - from the file “BackgroundFilter.plugin”
               Color Efex Pro 4 4.200, Copyright © 2000-2013 Google - from the file “Color Efex Pro 4.plugin”
               Dfine 2 2.200, Copyright © 2003-2012 Google - from the file “Dfine2.plugin”
               FineStructuresFilter 2.200, Copyright © 2003-2012 Google - from the file “FineStructuresFilter.plugin”
               HDR Efex Pro 2 2.100, Copyright © 2000-2013 Google - from the file “HDR Efex Pro 2.plugin”
               HotPixelsFilter 2.200, Copyright © 2003-2012 Google - from the file “HotPixelsFilter.plugin”
               Merge to HDR Efex Pro 2 2.100, Copyright © 2000-2013 Google - from the file “HDR Efex Pro 2 Automation.plugin”
               Nik Collection Selective Tool 2.105, Copyright © 2000-2013 Google - from the file “SelectivePalette.plugin”
               ShadowsFilter 2.200, Copyright © 2003-2012 Google - from the file “ShadowsFilter.plugin”
               Sharpener Pro 3: (1) RAW Presharpener 3.100, Copyright © 2000-2012 Google - from the file “SHP3RPS.plugin”
               Sharpener Pro 3: (2) Output Sharpener 3.100, Copyright © 2000-2012 Google - from the file “SHP3OS.plugin”
               Silver Efex Pro 2 2.100, Copyright © 2000-2013 Google. - from the file “Silver Efex Pro 2.plugin”
               SkinFilter 2.200, Copyright © 2003-2012 Google - from the file “SkinFilter.plugin”
               SkyFilter 2.200, Copyright © 2003-2012 Google - from the file “SkyFilter.plugin”
               StrongNoiseFilter 2.200, Copyright © 2003-2012 Google - from the file “StrongNoiseFilter.plugin”
               Viveza 2 2.100, Copyright © 2012 Google - from the file “Viveza2.plugin”
            Plug-ins that failed to load: NONE
            Flash:
               Mini Bridge
               Kuler
               Adobe Exchange
            Installed TWAIN devices: NONE
            • 3. Re: Why does the Panorama feature in Photoshop CC crash?
              Noel Carboni Level 8
              I'd say there's a good chance you'll get better behavior from Photomerge if you set your Cache Levels to 6 in your Performance preferences.  You've got that set to 1 at the moment, which can help with increasing the preview accuracy when zoomed out, but comes with some downsides.
              -Noel
              • 4. Re: Why does the Panorama feature in Photoshop CC crash?
                P.S. Remember to Quit and restart Photoshop after changing that setting.
                -Noel
                • 5. Re: Why does the Panorama feature in Photoshop CC crash?
                  rickhawaii Level 1
                  Thanks for the info. IT WORKED. Also fixed some other issues that I had. Thanks again. Rick Brandt
