• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Flash Button Component inside of a SWC
Community Expert ,
Mar 25, 2014 Mar 25, 2014
I'm publishing a SWC from FlashCC for use in a FlashBuilder Air project and I get errors when I compile.
Inside of the SWC I have a MovieClip with a button component (fl.controls.Button). In Flash Builder I can make an instance of the MovieClip but when I run the app I get a coercion error:
cannot convert flash.display::MovieClip@56ebee1 to fl.controls.Button.
If I remove the button component from the MovieClip and recompile the SWC there's no error.
If i simply try to add a button instance like this:
var b:Button=new Button();
trace(b);
addChild(b);
The button traces but I get this error
[object Button]
TypeError: Error #2007: Parameter child must be non-null
Views
543
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
Is it possible the SWC tries to instantiate a class that is referenced through a library?
Votes
Translate
Translate
Report
Report
Community Expert ,
Mar 26, 2014 Mar 26, 2014
LATEST
When adding a Button directly to the app I can solve the null problem by setting the default button styles, which are included in the SWC like this:
            var btn:Button=new Button();
            btn.setStyle( "upSkin", new Button_upSkin());
            btn.setStyle( "downSkin", new Button_downSkin());
            btn.setStyle( "overSkin", new Button_overSkin());
            btn.setStyle( "disabledSkin", new Button_disabledSkin());
            btn.setStyle( "selectedUpSkin", new Button_selectedUpSkin());
            btn.setStyle( "selectedDownSkin", new Button_selectedDownSkin());
            btn.setStyle( "selectedOverSkin", new Button_selectedOverSkin());
            btn.setStyle( "selectedDisabledSkin", new Button_selectedDisabledSkin());
            btn.label="Hello";
            btn.width=100;
            btn.height=22;
            airapp.addChild(btn);
What I really want to do is avoid the coding and make button and other component instances inside of MovieClips in Flash and include them in the SWC.
I can get components to work with Flash Professional Projects, but this is an ActionScript Project, so I need the SWC.
Votes
Translate
Translate
Report
Report
