3 Replies Latest reply on Mar 25, 2014 10:49 PM by Trevor.Dennis
    brushes will not overlap
    jacobkemple
      Hi, so I use photoshop as a drawing program and draw outlines on one layer then make another layer underneath to color in. normaly while coloring in if i mess up or dont like the colo i can change the brush color and brush over the old color but for some reason all of a sudden i am not able to brush over older brush strokes with a different color and am not sure why, all my settings seem to be normal any help would be appreciated?
        • 1. Re: brushes will not overlap
          Trevor.Dennis Adobe Community Professional (Moderator)
          Check your brush mode in the Options bar.
          What brush preset are you using?  (Try resetting your brushes, and selecting the first brush in the panel.)
          Are you trying to draw outside of an active selection?
          What is your brush opacity set to?  (It is oh so easy to hit a number key and set it to a very low opacity.)
          Are your strokes hidden by a filled layer higher up the layer stack?
          What are the layer blend modes set to?
          If none of this helps, and you have not fixed it yourself (and I'm betting that you have) upload a screen grab showing your entire workspace, and make sure the Layers panel is showing.  And please don't downsize before uploading.
          • 2. Re: brushes will not overlap
            jacobkemple Level 1
            I ended up having the mode set to something weird. thanks so much for you help though.
            • 3. Re: brushes will not overlap
              Thanks for letting us know.  I do it all the time.  Fingers move faster than my brain, and I action shortcuts I didn't even know were there!  Or I just plain forget I was cleaning an alpha channel and left the brush in Overlay mode etc. etc. etc.
