13 Replies Latest reply on Aug 29, 2007 10:49 AM by SymTsb
    trouble with URLLoaderExample
    ethanDC Level 1
      I have set up the example from the URLLoader class as directed. When I run the code I get this error:
      ioErrorHandler: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032: Stream Error. URL: file:///C|/Documents%20and%20Settings/Administrator/My%20Documents/Flash%20Projects/Essen tialAS3/src/urlLoaderExample.txt"]
      I am pretty sure I set up the files correctly because if I switch the URLRequest paramater to a jpg file the operation works fine.
      I saved the note pad text file in the same directory as the swf. I saved it using UTF-8. The only content is :
      Anyone have a clue why it isn't working?
