4 Replies Latest reply on Mar 26, 2014 1:40 AM by tobias.wantzen
    [CC, JS]: Supress Typekit Warning
    tobias.wantzen Level 1
      Hello together,
      after opening a document in my script, I tried to test, whether all needed fonts are installed with Dave Saunders hint:
      try {
        fontLocs = app.activeDocument.fonts.everyItem().location;
      } catch (e) {
        errorExit("Active document has missing fonts; please correct using Type/Find Font and try again.");
      But testing this by deactivating needed fonts and running the script, there is the Typekit font alert, which prompts directly after opening the doc and the routine I implemented is ignored.
      Are there any ways around this?
      Thanks!
      Tobias
        • 1. Re: [CC, JS]: Supress Typekit Warning
          Jump_Over Level 5
          Missing and deactivating differ, I am afraid.
          Possibly deactivated still has a path (cann't check it). You can check it comparing font.location.
          If yes - you should back to the way with looping through for status.
          However one can exam a result string of this (no loop):
          mString = app.activeDocument.fonts.everyItem().status.join();
          playing with string.match() or string.search() leads to needed alert, i.e:
          if (mString.match(/installed/ig).length != app.activeDocument.fonts.length)
               alert ("some missing font detected");
          Jarek
          • 2. Re: [CC, JS]: Supress Typekit Warning
            Hi Jarek,
            that’s not my problem. David’s code works perfectly fine, when the document is already open and the fonts are missing. But when I do this:
            _dok = app.open("/path/to/the/document/xyz.indd");
            try {
              fontLocs = _dok.fonts.everyItem().location;
            } catch (e) {
              alert("Active document has missing fonts; please correct using Type/Find Font and try again.");
            InDesign opens the doc, but immediately shows the Typekit dialogue »missing fonts«. After closing the Typekit dialogue nothing more happens – the script’s font check simply is ignored.
            Any suggestions?
            Tobias
            • 3. Re: [CC, JS]: Supress Typekit Warning
              Jump_Over Level 5
              What about switching this:
              app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
              app.scriptPreferences.userInteractionLevel = UserInteractionLevels.INTERACT_WITH_ALL;
              Jarek
              • 4. Re: [CC, JS]: Supress Typekit Warning
                Hej Jarek,
                thanks for your kind support. I used a combination of both of your hints and it works. With Dave’s code it doesn’t.
                Thanks a lot!
                Tobias
