5 Replies Latest reply on Mar 27, 2014 2:38 AM by BEGINNER_X
    TOC parameter
    BEGINNER_X Level 3
      Hi Genius,
      Could anyone help how to save the TOC parameter in the variable that already defined in the active document.
      My request need to save the parameters for the following entries:
      1. Entry Style
      2. Page Number
      3. Between Entry and Number
      4. etc....
      Trying coding is below:
      //Working fine
      var myTocStyle = app.activeDocument.tocStyles.item(-1).name;
      alert("myTocStyle: " + myTocStyle)
      var myTitleStyle = app.activeDocument.tocStyles.item(-1).titleStyle.name;
      alert("myTitleStyle: " + myTitleStyle)
      //Not working
      var myFormatStyle = app.activeDocument.tocStyleEntries.formatStyle.name;
      alert("myFormatStyle: " + myFormatStyle)
      var myPageNumber = app.activeDocument.tocStyleEntries.pageNumberPosition;
      alert("myPageNumber: " + myPageNumber)
      var mySeperator = app.activeDocument.tocStyleEntries.separator;
      alert("mySeperator: " + mySeperator)
      Please help for my urgent request.
      Beginner_X
        • 1. Re: TOC parameter
          Jump_Over Level 5
          1. TOCStyle is a parent for TOCStyleEntry (not document)
          2. TOCStyleEntries is a collection, so you can call a specific property for one of them, say tocStyleEntries[0] or tocStyleEntries.itemByName("FM_H1")
          In your example:
          var myPageNumber = myTocStyle.tocStyleEntries.itemByName("FM_H1").pageNumberPosition;
          Jarek
          • 2. Re: TOC parameter
            BEGINNER_X Level 3
            Hi Jump,
            Thanks for your immediate response...
            I tried your code, but it not works for me, may I did mistake, please clear my code
             //~ var myPageNumber = myTocStyle.tocStyleEntries.itemByName("FM_H1").pageNumberPosition;   //Jump_Over Code
            //~ var myPageNumber = myTocStyle.tocStyleEntries.item(0);
            //~ var myEntryStyle = myTocStyle.tocStyleEntries.item(0).formatStyle.name;
            var myEntryStyle = myTocStyle.tocStyleEntries.formatStyle.name;
            alert("myEntryStyle: " + myEntryStyle)
            Output that I need is:
            As per my attachment, in above line (alert for myEntryStyle) should be "FM_H1" style. Then i got the output.
            Thanks in advance
            Beginner
            • 3. Re: TOC parameter
              Jump_Over Level 5
              Just to be sure if there are any entries:
              var mTOCStyle = app.activeDocument.tocStyles[-1];
              alert (mTOCStyle.tocStyleEntries.everyItem().name);
              Notice that your mTocStyle is a name (string);
              Notice that it can be no entries or - using names - it should be present.
              Jarek
              • 4. Re: TOC parameter
                Jump_Over Level 5
                so you should start with lines like this:
                var myTocStyle = app.activeDocument.tocStyles[-1];
                alert("myTocStyle: " + myTocStyle.name);
                Jarek
                • 5. Re: TOC parameter
                  BEGINNER_X Level 3
                  Hi Jump,
                  Thanks a lot for your valuable timing!!!
                  I got solution for my request with the help of your tips.
                  var myFormatStyle = app.activeDocument.tocStyles.item(-1).tocStyleEntries.item(0).formatStyle.name;
                  var myPageNumberPosition = app.activeDocument.tocStyles.item(-1).tocStyleEntries.item(0).pageNumberPosition;
                  alert("myPageNumberPosition: " + myPageNumberPosition)
                  var mySeparator = app.activeDocument.tocStyles.item(-1).tocStyleEntries.item(0).separator;
                  alert("mySeparator: " + mySeparator)
                  Again thanks a lot.
                  Beginner
