2 Replies Latest reply on Mar 27, 2014 7:25 AM by Green4ever
    Bug?: layers.add() is not working properly when invoked from menu (ID/CS6/Win7)
    Green4ever Level 3
      Hello Devs,
      I am facing a mysterious issue with the layers.add() method.
      I am trying to create n number of layers for my document. So I have decided to create a menu for this.
      I have creatd two scripts
      1. For creating menu & menu action,
      2. Actual script that creates n number of layers.
      When I run the script #2 direclty from ESTK it works fine.
      Now when I try to invoke the same script from the Menu it is not working fine. Only the last layer is created.
      Script 1: LayerPopupMenuAction
      #target indesign
      #targetengine createLayerset
      var layerTemplateScript = File(File(getActiveScriptPath()).parent.fsName+"/IntializeTemplate.jsx");
      var initTemplateHandler = {
          'beforeDisplay' : function(ev)
                  ev.target.enabled = (app.documents.length>0);
          'onInvoke' : function()
                  app.doScript(layerTemplateScript, ScriptLanguage.JAVASCRIPT, undefined, UndoModes.FAST_ENTIRE_SCRIPT, "Initialize Script");
      var layerMenuAction = app.scriptMenuActions.add("&Create Layer Set");
      for(var init_ev in initTemplateHandler) {
          layerMenuAction.eventListeners.add(init_ev, initTemplateHandler[init_ev]);
      var refMenuItem = app.menus.item("$ID/LayerPanelPopup");
      refMenuItem.menuItems.add(layerMenuAction, LocationOptions.AFTER, refMenuItem.menuItems.item(2));
      function getActiveScriptPath() {
          // This function returns the path to the active script, even when running from ESTK
          try {
              return app.activeScript;
          } catch(e) {
              return e.fileName;
      Script 2: IntializeTemplate
      #target indesign
      if (app.documents.length == 0){
          alert("Please open a document and try again", "Document Error", true);
          exit();
      var templateDoc = app.activeDocument;
      var layerNameArray = ["Fixed_Static_Assets", "Absolute_User_Assets", "Relative_User_Assets"];
      CreateLayers(layerNameArray);
      alert("Initialization Successful");
      //--------------------------------FUNCTIONS ARE DEFINED HERE--------------------------------
      function CreateLayers(LayerNameList){
          var layerListLength = LayerNameList.length;
          var layerObject;
          for (var ln=0; ln<layerListLength; ln++){
              layerObject = templateDoc.layers.itemByName(LayerNameList[ln]);
              if (layerObject.isValid==false){
                  layerObject = templateDoc.layers.add({name:LayerNameList[ln]});
                  //$.writeln('Layer Creation: ' + layerObject.isValid + ' for '+layerObject.name);
          //Merger Default Layer with the bottom layer:
          var defaultLayer = templateDoc.layers.itemByName("Layer 1");
          if(defaultLayer.isValid==true){
              //$.writeln('Default is Valid and will be merged with top most layer');
              layerObject.merge([defaultLayer]);
      Any help / guidance on this regard will be much helpful.
      @Marijan Tompa [tomaxxi]: I googled for the solution and noticed that you have already worked on similar type of script. Please help me if you can.
      Green4ever
