1. Re: Stacking 3D objects and maintain correct perspective
Mylenium Mar 26, 2014 8:51 AM (in response to shawninvancouver)Would be fantastic if PS supported persistent projection baking in its 3D part, would it not? Would make this a walk in the park. Otehrwise you will have to muddle through. A good place to start would be to separate the faces so they can be warped and skewed separately, then clone them as needed. Ultimately you will only need one top face - more or less - anyway.
Mylenium
2. Re: Stacking 3D objects and maintain correct perspective
shawninvancouver Mar 26, 2014 10:27 AM (in response to Mylenium)Mylenium wrote:
Mylenium
Thank you for your reply Mylenium!
"separate the faces"
That is what I am already doing but I didn't want to taint the conversation with what I though might not be the best method.
What I am doing is separating the face, the top, and the side (3 separate layers) and skew the heck out of the back to pieces, and finally, a little bit of free transform to make everything mostly fit together. I real pain... especially manually masking the face plate (because there is not enough contrast to use the magnetic lasso).
I guess we need to go here and make a feature request (not sure it helps)? https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform&product=12
Wondering if there are any other ideas (besides getting new photos)?
