2 Replies Latest reply on Mar 26, 2014 12:40 PM by A.T. Romano
    PrE9 - Import Issues from SD Card
    mrtilleypops01
      I am using elments 9. I start a new project import new video from my Sd card and work on the project Take out the Sd card and save the new project to the C drive video.Whe I try to open the same project it will not open untill I put in the SD card with the original Video clips on. If I put the SD card back it will open the programme. This has only just started to happen What am I doing wrong
      [Title edited for clarity - Hunt]
        • 1. Re: Question
          Does it work if you follow the directions below and copy the full contents of your SD card to your data drive?
          Metadata contained in folder http://forums.adobe.com/thread/1015001?tstart=0
          -and http://helpx.adobe.com/premiere-pro/using/transferring-importing-files.html
          -http://helpx.adobe.com/premiere-pro/using/importing-assets-tapeless-formats.html
          • 2. Re: Question
            A.T. Romano Level 7
            mrtilleypops01
            The part about your question that made me stop and do a double think for an answer related to when you wrote
            When you insert an SD card into the SD slot of a computer, typically a pop up appears asking you what you want to do
            with this SD card. When things were working the way you wanted, you may have been selecting Import Photos/Videos or something else in
            that computer message so that the files were copied to a location on the computer side of things. The Premiere Elements project would have
            that permanent hard drive save location to reference back to. It would not have to wait for you to insert the SD card back into
            the computer to get its source media from the only place it knew them to be.
            Does any of that sound like it applies to your situation?
            I would suggest that you transfer the files to a hard drive save location or an external hard drive and from there import them
            into your project with its Get Media/Files and Folders. Lots of variations. So, we could discuss this further if we seem to be
            going in the right direction.
            Looking forward to your follow up.
            Thanks.
            ATR
