2 Replies Latest reply on Jun 1, 2007 9:12 AM by Voddie
    transitions and inertia
    Voddie
      Hi
      Im working on an effect and have succeeded in using as to bring a mc into view, upsize for a while and then downsize.
      I have used easing and wondered if anyone could enlighten me on changing the effect to inertia, so instead of it bouncing, it eased to its final rest.
      Thanks in advance for any help offered
      voddie
        • 1. Re: transitions and inertia
          Damon Edwards Level 3
          Easing Class
          Description
          Back
          Extends the animation once beyond the transition range at one or both ends to give the effect of being pulled back from beyond its range.
          Bounce
          Adds a bouncing effect within the transition range at one or both ends. The number of bounces relates to the duration--longer durations produce more bounces.
          Elastic
          Adds an elastic effect that falls outside the transition range at one or both ends. The amount of elasticity is unaffected by the duration.
          Regular
          Adds slower movement at one or both ends. This feature lets you add a speeding up effect, a slowing down effect, or both.
          Strong
          Adds slower movement at one or both ends. This effect is similar to the Regular easing class, but it's more pronounced.
          None
          Adds an equal movement from start to end without effects, slowing, or speeding up. This transition is also called a linear transition.
          These six easing calculation classes each have three easing methods, which indicate at what part of the animation to apply the easing effect. In addition, the None easing class has a fourth easing method: easeNone. The easing methods are described in the following table:
          Method
          Description
          easeIn
          Provides the easing effect at the beginning of the transition.
          easeOut
          Provides the easing effect at the end of the transition.
          easeInOut
          Provides the easing effect at the beginning and end of the transition.
          easeNone
          Indicates no easing calculation is to be used. Provided only in the None easing class.
          • 2. Re: transitions and inertia
            Voddie Level 1
            Hey
            Thankls for the info, very useful.
            In some movies Ive seen, they get the image/mc to nudge up at the end of the movement, ie. pixel by pixel until come to rest.
            Can this be acheived using these transitions?
            Thanks again
            Voddie
