3 Replies Latest reply on Mar 26, 2014 2:36 PM by A.T. Romano
    PE 12 - No Sound Effects
    Bitznbytes
      Fresh install of PE 12 with all updates on Windows 8.1 and the Sounds Effects section is all greyed out. The Music Scores are showing but no Sound Effects. HELP!
      B
        • 1. Re: PE 12 - No Sound Effects
          A.T. Romano Level 7
          B
          Update 12 to 12.1 using Premiere Elements 12 new project opened to Help Menu/Updates.
          This may call for a Sign Out, Uninstall, ccleaner run through, reinstall with antivirus and firewalls turned Off, but first let us
          try to delete the Premiere Elements 12 Settings file. For Windows 8.1 64 bit, the path is
          Local Disc C
          Users
          Owner
          AppData
          Roaming
          Adobe
          Premiere Elements
          12.0
          and in the 12.0 Folder should be the Adobe Premiere Elements Prefs file that you delete. If that does not work, then you delete the whole
          12.0 Folder in which the Adobe Premiere Elements Prefs file exists. Be sure not to detour off the folders path cited. Also make sure to be working
          with Folder Option Show Hidden Files, Folders, and Drives active so that you can see the complete path cited.
          Restart the computer in this plan.
          Please let us know the outcome. We will plan additional troubleshooting strategy if necessary.
          Thank you.
          ATR
          • 2. Re: PE 12 - No Sound Effects
            Bitznbytes Level 1
            Hey,
            That was fast! Thanks for the reply so quickly! Just went back in and they are now showing. Wonder, did they need to download first? How many catagories are there suppose to be?
            B
            • 3. Re: PE 12 - No Sound Effects
              A.T. Romano Level 7
              Bitznbytes
              Great news. Glad the Sound Effects showed up. I have run into details in their appearance.
              These of the Sound Effects categories that is I have for my Premiere Elements 12 (Windows 7, 8, or 8.1 64 bit)
              And these are numerous choices under each of those categories of Sound Effects. I
              actually took on the task of counting the number of individual Sound Effects
              Sound Effects has 13 subcategories and a total of 267 or 268 free sound effects. The Sound Effects subcategories and the number of sound effects in them are Ambience (49), Animals (10), Cartoon Effects (20), Crashes (10), Fire and Explostions (18), Foley (30), Impacts (20), Industry (10), Liquids (10), Science Fiction (30), Technology (29 or 30), Transportation (11), and Weather (20).
              The above was quoted from my blog post on Premiere Elements 12 First Look.
              http://www.atr935.blogspot.com/2013/09/premiere-elements-12-first-look-details.html
              Thanks for the follow up.
              ATR
