• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Content of HHK file is not reflected in CHM
New Here ,
May 30, 2007 May 30, 2007
I have created an index using the Smart Index Wizard based on the Topic Title only. After tidying up unwanted keywords, I removed some of the multiple topics linked to some keywords (typically those that can be accessed from other linked topics already listed against that keyword). I did this by editing the HHK and removing the unwanted links. Saved the HHK. No problem here.
I also edited some of the Topic Titles in the HHK file so that they are more specific. When seen via the Index section (RH X5) in the Index Keyword Properties window, the Topic Titles have been changed accordingly. However, when running the CHM, it still uses the old Titles, as if those titles don't actually come from the HHK file or are being cached from somewhere else.
I exited RH many times. Copied the CHM to some unrelated folder but no difference. Anybody knows where those Topic Titles in the Topic Found window (1 keyword pointing to multiple links) are coming from?
Michel
Views
256
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here , Jun 01, 2007 Jun 01, 2007
Rick,
Thank you very much. It worked.
Any side effects to de-setting that Binary option? Is that only for sorting? Wondering why it doesn't simply say 'Sort?
Regards
Michel
Votes
Translate
Translate
Valorous Hero ,
Hi Michel
Perhaps you might try clicking File > Project Settings... and DE-Selecting the Binary Index check box.
Note that after you do this, you will probably need to sort the index manually. This is easy enough. Just right-click any root level index term and choose Sort > Current Level and Below.
Cheers... Rick
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Rick,
Regards
Michel
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
