2 Replies Latest reply on Mar 28, 2014 5:00 PM by iccsi
    trigger onchange event by load server data
    iccsi Level 1
      I have following code to filter my second list from my list.
      It works when user click the dropdown, since onchange event trigger.
      I tried to load the data from stored procedure then the onchange event does not trigger, when user need update data then will see whole list without filtering.
      I would like to know if it is possible to trigger onchange event when I load data from stored procedure,
      Your help and information is great appreciated,
      Regards,
      Iccsi,
      <td><select name="Mylst" id="Mylst">
               <cfoutput query="MySP">
                        <option value="#MySP.MyID#"
                <cfif (isDefined("form.MyID") AND form.MyID EQ MySP.MyID)>selected="selected"</cfif>> #MySP.MyName# </option>
                </cfoutput>
           </select></td>
      $("#Mylst").change(function()
              {    $.ajax({
                           type: "GET",
                           url:   'Mycfc.cfc?method=GetMethod&MyParam='+ jQuery("#MyPrelsty").val(),
                           dataType: "json",
                   cache: false,
                           success: function(data)
                    $('#MySublst option').remove();
               $.each(data, function(i, obj)
                   $("#MySublst").append('<option value=' + '"' + data[i][0] + '"' +'>' + data[i][1] +
      '</option>')
