8 Replies Latest reply on Apr 2, 2014 4:44 AM by hparmar
    Video Usage
    FreddyNuke
      IS there anyway to determine how many times a video has been access in AMS 5? I have looked at the apache log, but a streamed video appears many time for just one playing. Thanks for any help.
        • 1. Re: Video Usage
          jim_houseman
          You can use the server-side scripting API  to increment a counter each time a certain resource is accessed.
          http://help.adobe.com/en_US/adobemediaserver/ssaslr/WS5b3ccc516d4fbf351e63e3d11a11aff5ba-7 f8bSSASLR.2.3.html
          Or
          http://help.adobe.com/en_US/adobemediaserver/adminapi/WSa4cb07693d12388431df580a12a34991eb c-8000.2.3.html
          Personally, I'd probably not try to handle this through AMS. I'd get and save the number of views to a given resource to a separate database.
          • 2. Re: Video Usage
            FreddyNuke Level 1
            Thanks for your response, but I'm really new at AMS. I can develope in ASP.Net. With that said, can you elaborate in a little more detail how to accomplish this. Perhaps the method name to use or a sample code snippet would be greatly.
            • 3. Re: Video Usage
              jim_houseman Level 1
              Sure. It's just javascript.
              If you only have one video in your application:
              var accessCount=0;
              application.onConnect = function (client){
                   accessCount++;
              Or if you want to track a specific video:
              var accessCount;
              application.onConnect = function (client,resource){
                   accessCount[resource]++;
              where "resource" is a string variable that you pass when the client application connects to the server.
              And if you want to retrieve this number from your client:
              Client.prototype.getMetrics = function(resource){
                        return accessCount[resource];
              Or you could even use the File class and write to an exteral file if you wanted.
              • 4. Re: Video Usage
                hparmar Adobe Employee
                if you are looking for a solution to rtmp streams then Jim's answer is one of the ways...You can also inspect access log for AMS(not apache) to find put rmtp streams/clients playing a stream.
                Howeever if you want to look for statistics for HDS/HLS streaming(which happens through Apache and its modules) then you will have to look at Apache logs(access logs for Apache)
                • 5. Re: Video Usage
                  FreddyNuke Level 1
                  Most of my videos are HDS. I looked at the Apache log, but need a little help in parsing the log for multi bit rate streaming. One playing of a video generates many, many entries into the log. For example:
                  124......... - - [31/Mar/2014:02:29:22 -0400] "GET /hds-vod/Vogtle_800.f4v.f4m HTTP/1.1" 200 2025
                  124......... - - [31/Mar/2014:02:29:22 -0400] "GET /hds-vod/Vogtle_1500.f4v.f4m HTTP/1.1" 200 2028
                  124......... - - [31/Mar/2014:02:29:45 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag1 HTTP/1.1" 200 97018
                  124......... - - [31/Mar/2014:02:29:46 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag2 HTTP/1.1" 200 161506
                  124......... - - [31/Mar/2014:02:29:49 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag3 HTTP/1.1" 200 1040005
                  124......... - - [31/Mar/2014:02:29:55 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag4 HTTP/1.1" 200 834187
                  124......... - - [31/Mar/2014:02:30:01 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag5 HTTP/1.1" 200 366308
                  124......... - - [31/Mar/2014:02:30:03 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag6 HTTP/1.1" 200 401652
                  124......... - - [31/Mar/2014:02:30:06 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag7 HTTP/1.1" 200 221894
                  124......... - - [31/Mar/2014:02:30:12 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag8 HTTP/1.1" 200 371067
                  124......... - - [31/Mar/2014:02:30:14 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag9 HTTP/1.1" 200 506740
                  124......... - - [31/Mar/2014:02:30:18 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag10 HTTP/1.1" 200 538230
                  124......... - - [31/Mar/2014:02:30:22 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag11 HTTP/1.1" 200 449507
                  124......... - - [31/Mar/2014:02:30:28 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag12 HTTP/1.1" 200 321969
                  124......... - - [31/Mar/2014:02:30:30 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag13 HTTP/1.1" 200 429534
                  124......... - - [31/Mar/2014:02:30:36 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag14 HTTP/1.1" 200 415903
                  124......... - - [31/Mar/2014:02:30:38 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag15 HTTP/1.1" 200 533145
                  124......... - - [31/Mar/2014:02:30:44 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag16 HTTP/1.1" 200 336615
                  124......... - - [31/Mar/2014:02:30:46 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag17 HTTP/1.1" 200 519305
                  124......... - - [31/Mar/2014:02:30:50 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag18 HTTP/1.1" 200 533103
                  124......... - - [31/Mar/2014:02:30:53 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag19 HTTP/1.1" 200 658543
                  124......... - - [31/Mar/2014:02:30:59 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag20 HTTP/1.1" 200 894845
                  124......... - - [31/Mar/2014:02:31:06 -0400] "GET /hds-vod/Vogtle_800.f4vSeg1-Frag21 HTTP/1.1" 200 883363
                  124......... - - [31/Mar/2014:02:31:11 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag22 HTTP/1.1" 200 363477
                  124......... - - [31/Mar/2014:02:31:16 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag23 HTTP/1.1" 200 175650
                  124......... - - [31/Mar/2014:02:31:17 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag24 HTTP/1.1" 200 528201
                  124......... - - [31/Mar/2014:02:31:22 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag25 HTTP/1.1" 200 454561
                  124......... - - [31/Mar/2014:02:31:25 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag26 HTTP/1.1" 200 705040
                  124......... - - [31/Mar/2014:02:31:31 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag27 HTTP/1.1" 200 367943
                  124......... - - [31/Mar/2014:02:31:34 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag28 HTTP/1.1" 200 139240
                  124......... - - [31/Mar/2014:02:31:37 -0400] "GET /hds-vod/Vogtle_300.f4vSeg1-Frag29 HTTP/1.1" 200 773752
                  How can get only the distinct viewing of the video?
                  • 6. Re: Video Usage
                    FreddyNuke Level 1
                    Perhaps I'm missing something. My videos are mainly packaged as manifest files and embeded as html objects in our training applicationa, internet/intrannet, etc...
                    Are you saying the javascript should be added to the page that host the html object?
                    • 7. Re: Video Usage
                      I am not saying that the javascript should be added to the page that hosts the html object.
                      I am assuming that your AMS application works like mine, which may be a false assumption.
                      But my folders  on the server are laid out like this:
                      Adobe Media Server 5\Applications\[name of application]\[name of application].asc
                      The javascript is in the .asc file.
                      This is similar to this
                      http://help.adobe.com/en_US/adobemediaserver/devguide/WS5b3ccc516d4fbf351e63e3d11a0773d56e -7ffdDev.2.3.html
                      When clients connect to your server, they hit the .asc file first. This is where you can accept, reject, or count connections.
                      • 8. Re: Video Usage
                        The following line indicates a request for manifest file( .f4m in this case)...There is a single manifest file generated per stream..so this request should tell you the video files being requested.
                        BTW on side note, the industry practice is to put a vranish in front of Apache web server and log/account all requests on varnish itself.
