1 Reply Latest reply on Mar 28, 2014 4:38 AM by Ned Murphy
    Help on AS2 keyListener script
    nelsonandjason
      Hi, I have been this ActionScript a lot -
      var keyListener:Object = new Object();
      Key.addListener(keyListener);
      function keyDownF(){
          play();
      keyListener.onKeyDown = keyDownF;
      But would like to know how to revise it so I could isolate the specific keys I do or don't want to be used.
      Also is it possible to disable so it only works at a particular part in my time line? If I use it now it will work on every frame.
      Any advice would be helpful.
      Thanks again
      Jason
        • 1. Re: Help on AS2 keyListener script
          Hi Jason, here is a simplified bit of code that works based on specific keys.  You would just replace the "trace()" commands with your intended actions...
          keyListener.onKeyDown = function(){
              // trace(Key.getCode()); // use this trace to determine other key codes
              if(Key.getCode() == 38) trace("up");
              if(Key.getCode() == 40) trace("down");
              if(Key.getCode() == 37) trace("left");
              if(Key.getCode() == 39) trace("right");
          As far as only allowing this to function in specific frames, you could utilize other conditionals that check if the _currentframe property is a value that allows for it.  You could also assign the Key.onKeyDown to be null when you do not want it to be active.
