4 Replies Latest reply on Jul 12, 2007 2:50 AM by JabbyPandaUA
    Amfphp --> Array --> horizontalList
    gongon2 Level 1
      Hi! (sorry for my poor english..)
      I'd try yo populate an horizontalList width a list of images defined by an array loaded from mySql through an amfPHP simple service.
      Data (images path) are loaded correctly in the movie (in fact, you can see them in the dataGrid) but the horizontalList return a list of empty image fields.
      You can see it here :
      http://www.gongon2.com/flex/pippo/bin/OrizList.html
      This is the source code :
      <?xml version="1.0"?>
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" height="208" width="800" creationComplete="initApplicationPippo()">
      <mx:Script>
      <![CDATA[
      import mx.collections.*;
      import mx.controls.Image;
      import mx.rpc.events.ResultEvent;
      import mx.utils.ArrayUtil;
      [Bindable]
      public var pippo:Array;
      public var gatewayPippo : RemotingConnection;
      public function initApplicationPippo():void{
      gatewayPippo = new RemotingConnection( " http://www.gongon2.com/flashservices/gateway.php" );
      gatewayPippo.call( "sampleOL.getUserPhoto", new Responder(onResult, onFault),"1");
      public function onResult( result : Array ) : void
      pippo = result;
      myList.dataProvider = pippo;
      public function onFault( fault : String ) : void
      trace( fault );
      </mx:Script>
      <mx:HorizontalList id="myList" columnWidth="100" rowHeight="100" columnCount="4" itemRenderer="mx.controls.Image" x="10" y="25" height="120" width="400"/>
      <mx:Image x="418" y="25" width="100" height="100" id="image" source="{myList.selectedItem.photoPath}"/>
      <mx:DataGrid dataProvider="{pippo}" x="578" y="25" id="grid" height="130" width="104">
      <mx:columns>
      <mx:DataGridColumn headerText="photoPath" dataField="photoPath"/>
      </mx:columns>
      </mx:DataGrid>
      <mx:Image x="690" y="25" width="100" height="100" source="{grid.selectedItem.photoPath}"/>
      </mx:Application>
        • 1. Re: Amfphp --&gt; Array --&gt; horizontalList
          gongon2 Level 1
          Anyone can help me??
          • 2. Re: Amfphp --&gt; Array --&gt; horizontalList
            JabbyPandaUA Level 3
            Instead of
            [Bindable]
            use
            [Bindable]
            public var pippo: ArrayCollection
            • 3. Re: Amfphp --&gt; Array --&gt; horizontalList
              gongon2 Level 1
              quote:
              Originally posted by: JabbyPandaUA
              Instead of
              [Bindable]
              use
              [Bindable]
              I'declared a new ArrayCollection (pippoColl), but the result seems to be the same.... blank images fields...
              <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" height="208" width="800" creationComplete="initApplicationPippo()">
              <mx:Script>
              <![CDATA[
              [Bindable]
              public var pippoColl:ArrayCollection;
              [Bindable]
              //mi collego al servizio e interrogo lo script (l' "1" dopo 'onFault' è l'id del soggetto di cui voglio avere
              //le foto)
              gatewayPippo = new RemotingConnection( " http://localhost/flashservices/gateway.php" );
              gatewayPippo.call( "sample3.getUserPhoto", new Responder(onResult, onFault),"1");
              pippo = result;
              initpippoColl(pippo);
              //myList.dataProvider = pippo;
              trace( fault );
              public function initpippoColl(items:Array):void
              pippoColl = new ArrayCollection(items);
              myList.dataProvider = pippoColl;
              </mx:Script>
              <mx:HorizontalList id="myList" columnWidth="100" rowHeight="100" columnCount="4" x="10" y="25" height="120" width="400" itemRenderer = "mx.controls.Image"/>
              <mx:columns>
              </mx:columns>
              </mx:DataGrid>
              </mx:Application>
              • 4. Re: Amfphp --&gt; Array --&gt; horizontalList
                Ok, back your question
                In your declaration
                I do not see where you set Image source property to a value.
                Please, rework your itemRenderer declaration to inline renderer where you set source property for the image
                http://www.adobe.com/devnet/flex/quickstart/using_item_renderers/
