1. Re: map id file (project.ali) in source countrol
Willam van Weelden Apr 1, 2014 1:36 AM (in response to peter_h)No way that I know of. But can't you just override the server version of
the file with the local file?
Kind regards,
Willam
2. Re: map id file (project.ali) in source countrol
peter_h Apr 3, 2014 12:12 AM (in response to Willam van Weelden)Well, I don't think that that would help.
The odd thing is that the order of the ids in the ali file are the same for all the even commits, and for the odd commits. The change of order is done by robohelp, so overriding the server version cannot help? Unless I did not correctly understand what you mean.
for example: Let's say that the ali file initially contains this ids:
-ID1
-ID2
-ID3
when adding a id, the order could now look like this:
-ID2
-ID4
-ID3
-ID1
When adding a fifth id, the order of the first 3 are now the same as in the beginning. The location of the 4th and the 5th seem random:
-ID1
-ID2
-ID4
-ID3
-ID5
When adding a sixth id, the order of the first 4 are now the same as in the second situation. The location of the 5th and the 6th seem random:
-ID2
-ID4
-ID5
-ID3
-ID6
-ID1
This happens when using a version control system or not, so this is probably a unwanted behaviour of robohelp?
We off course have to take into account that multiple users can change the ali file at the same time and because of the order changes, a difficult merge conflict often happens because of that.
