2 Replies Latest reply on May 29, 2007 4:43 PM by urbanrevolution
    checkbox component not working with form
    urbanrevolution Level 1
      ok so i;ve gon back to the down a dirty way of doing this...
      http://www.lightningmedia.com/form_test.php (technical info tab)
      each text field has a Var: Name, email, and company
      i've used the CheckBox component
      i;ve placed the fallowing code on the submit button
      on (release) {
      if (!email.length || email.indexOf("@") == -1 || email.indexOf(".") == -1) {
      EmailStatus = "Please enter a valid E-mail address";
      } else {
      loadVariablesNum("includes/techinfo_signup.php", 0, "POST");
      this.gotoAndStop(2);
      easy enough right?
      everything works fine but the CheckBox......
      i'm trying to send a 1 or 0 to the database.
      i've given the component a
      fieldname: newsletter (the same as the field in the database)
      data type: Boolean
      required: true
      Read only: false
      kind: data
      formatter:none
      encoding:none
      default value:1
      path: includes/techinfo_signup.php
      storage type: simple
      so what am i missing? i'm at a loss...
      thanks again
        • 1. Re: checkbox component not working with form
          Damon Edwards Level 3
          someone correct me if i'm wrong, but you'd handle the data by using
          instancename.value
          • 2. checkbox component not working with form
            not sure what you mean, sorry ..
            this is the first time i've ever used any kind of a component....
            so i'm shooting in the dark....
            i've put this on teh main time line
            newsletterListener = new Object();
            newsletterListener.click = function() {
            if(newsletter.selected) {
            var visitor_Copy = newsletter.text;
            trace("you will receive a copy")
            }else{
            trace("you will not receive a copy")
            newsletter.addEventListener("click", newsletterListener);
            i can see that on(click) it'll trace the action... but it also lists it as "undefined"
            undefined
            undefined
            undefined
            undefined
            but none of this seems to matter to my submit button.
            "crash & burn said the little checkbox."
