1 Reply Latest reply on Mar 28, 2014 8:46 AM by robboerman
    audio - toggle on/off multiple sounds even when they are not currently playing
    resdesign Adobe Community Professional & MVP
      I am wondering if there is a way to stop toggle all sounds even if they are not playing.
      What I mean by that is I have several sound files that play one at a time when a slide comes in. I can toggle on/of the current sound but what if I want to toggle all sounds on/off in the compostion even if they are not playing so that when I go to next slide it will be on or off depending what was chosen on the previous slide?
      One of the problem would be that I do not want all sounds to be turned back on at the same time but only the current one but I still want to be able to turn off all the sounds if the user decides he does not want to hear sound while at the same time I want the sounds to load automatically on each slide if he has decided to have sound.
      Hope this makes sense.
        • 1. Re: audio - toggle on/off multiple sounds even when they are not currently playing
          robboerman Level 4
          didn't have the time to test this code yet.
          but it should work.
          Html5 audio can not be accessed by class, it can only be accessed by id.
          so i made this code
          $( "audio" ).each(function() {
          var a = $(this).attr("id");
          var audioPlayer = document.getElementById(a)
              audioPlayer.pause();
              audioPlayer.currentTime = 0;
          this will find the id of the audios and pause them and reset the time to 0
          ( not really a way to officially stop audio )
          or you van just mute it with this code
              audioPlayer.muted = true;
          - Rob
