HI all,
I have a 25 minute wedding video that I have been unsuccessfully trying to export and sign off on nfor the last week and the problem seems to lie with Denoiser II. There were some clips that were corrupted by me using Denoiser on them so I had to take the effect off. However I am also having a problem in that the denoiser effects seems to 'flicker' during clips - ie it works for a second, then stops so noise appears, then works again for a second, then stops etc etc. The footage was shot on a dslr, 24fps. I shot a short film with the same clips and used denoiser a few weeks previously with no problems. The only thing that differs is the amount of other effects I am using with the footage - Colorista II, Mojo and Magic Bullet Looks. Could the problem be that I have too many effects running?
I can't view my footage in Premiere as my computer can't play it due to the effects I have on it so can't comment on whether the problem is happening in playback and export, or just when i export
I have tried exporting in h.264, mpeg etc. I have also tried exporting through Encoder rather than Premiere, again with no difference and am getting so frustrated.
Im on Premiere Pro cc and Windows 8
Any advice would be much appreciated
Thanks!
Tony
Hi Tony,
Make sure you have installed the most recent version of that plug-in. You might also want to contact Red Giant Support: http://www.redgiant.com/support/
Kevin
