7 Replies Latest reply on Mar 28, 2014 6:52 PM by A.T. Romano
    Audio from mp4 fails to import
    MENTALFiST
      Audio disappears from my .mp4 files in Premiere Elements 12. Howeverm it worked flawlessly in Premiere Pro CC on the same computer.
      Below you will find the information from MediaInfo.
      Thanks in advance!
      General
      Complete name                            : C:\Users\Ale\Videos\OBS\000.mp4
      Format                                   : MPEG-4
      Format profile                           : Base Media
      Codec ID                                 : isom
      File size                                : 5.29 MiB
      Duration                                 : 39s 100ms
      Overall bit rate                         : 1 134 Kbps
      Encoded date                             : UTC 2014-03-20 14:50:15
      Tagged date                              : UTC 2014-03-20 14:50:15
      Writing application                      : Open Broadcaster Software v0.613b
      Video
      Format                                   : AVC
      Format/Info                              : Advanced Video Codec
      Format profile                           : High@L3.2
      Format settings, CABAC                   : Yes
      Format settings, ReFrames                : 4 frames
      Muxing mode                              : Container profile=High@3.1
      Codec ID                                 : avc1
      Codec ID/Info                            : Advanced Video Coding
      Source duration                          : 39s 67ms
      Bit rate                                 : 1 000 Kbps
      Width                                    : 1 280 pixels
      Height                                   : 800 pixels
      Display aspect ratio                     : 16:10
      Frame rate mode                          : Variable
      Frame rate                               : 30.000 fps
      Minimum frame rate                       : 29.412 fps
      Maximum frame rate                       : 30.303 fps
      Color space                              : YUV
      Chroma subsampling                       : 4:2:0
      Bit depth                                : 8 bits
      Scan type                                : Progressive
      Bits/(Pixel*Frame)                       : 0.033
      Stream size                              : 4.65 MiB (88%)
      Source stream size                       : 4.65 MiB (88%)
      Writing library                          : x264 core 140 r2380 3dcf6e2
      Encoding settings                        : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=cbr / mbtree=1 / bitrate=1000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=1000 / vbv_bufsize=1000 / nal_hrd=none / filler=1 / ip_ratio=1.40 / aq=1:1.00
      Color primaries                          : BT.709
      Transfer characteristics                 : sYCC
      Matrix coefficients                      : BT.709
      mdhd_Duration                            : 39100
      Audio
      Format                                   : MPEG Audio
      Format version                           : Version 1
      Format profile                           : Layer 3
      Codec ID                                 : 6B
      Duration                                 : 39s 93ms
      Source duration                          : 39s 79ms
      Bit rate mode                            : Constant
      Bit rate                                 : 128 Kbps
      Channel(s)                               :  channel0
      Channel(s)_Original                      : 2 channels
      Sampling rate                            : 44.1 KHz
      Compression mode                         : Lossy
      Stream size                              : 611 KiB (11%)
      Source stream size                       : 611 KiB (11%)
      Writing library                          : LAME3.99.5
      mdhd_Duration                            : 39053
        • 1. Re: Audio from mp4 fails to import
          I am VERY surprised that your video worked in PProCC, since variable frame rate video is not supported
          Adobe/Jive have a BAD title for the SEARCH THIS FORUM function
          Go back to http://forums.adobe.com/community/premiere_elements or http://forums.adobe.com/community/premiere
          And, in the area just under Ask a Question, type in
          variable frame rate
          You may now read previous discussions on this subject... be sure to click the See More Results at the bottom of the initial, short list if the initial list does not answer your question
          • 2. Re: Audio from mp4 fails to import
            MENTALFiST Level 1
            Hmm interesting, the software I used to record it is quite widely used so I assumed its encoding would be somewhat regular. The video works in all software (windows movie maker, PE12, PProCC) but audio has only worked in PProCC. The frame rate should be 30 anyways, I do not know why the mode is set to variable.
            I searched for variable frame rate and found nothing in regards to my problem.
            • 3. Re: Audio from mp4 fails to import
              A.T. Romano Level 7
              MENTALFiST
              Please clarify what is happening with the audio...
              a. If you are using Add Media/Files and Folders/Project Assets,  and drag the AVCHD.mp4 from there to the Timeline Video 1/Audio 1, you do not see an audio file on Audio 1 or you do not hear audio from Audio 1 at playback?
              Variable frame rate does not automatically spell Premiere Elements failure. But, constant frame rate may be needed to over some audio out of sync issues. But from what you describe, you have no audio that has the opportunity to be out of sync.
              In the likelihood that the .mp3 audio in the AVCHD.mp4 file may be causing the problem, let us look at converting the file in HandBrake and see what happens with a constant frame rate of 30 frames per second AVCHD.mp4 but with AAC audio.
              a. Download and install the free HandBrake program.
              http://handbrake.fr/
              b. In the HandBrake program
              Source Open File
              I set for seconds
              Destination..Browse to desktop and name your ..MP4 Container
              Leave the Picture Tab settings as is for now
              Go to the Video Tab
              Video Codec: H.264 (x264)
              Framerate (FPS): 30
              dot Constant  Framerate
              Hit Start and wait until you see Queue Finished at bottom left progress display.
              Please let us know the outcome and then we can weigh our options moving forward with the troubleshooting.
              Thanks for your helpful information.
              ATR
              • 4. Re: Audio from mp4 fails to import
                MENTALFiST Level 1
                Sorry for unclear post. I see no audio track on Audio 1 at all, as you assumed.
                I followed your instructions, and the outputs audio seems to work in PE12.However, I'd rather find some other way of solving this problem than converting all my files, I have over 150 files alltogether that Iwish to use in PE12.
                edit: I set up a queue to convert all my files, only seems to take around 20 minutes.. Thanks for the advice! But if you have any other ideas on how to fix the problem I'd love to hear them for future use!
                • 5. Re: Audio from mp4 fails to import
                  A.T. Romano Level 7
                  MENTALFIST
                  Thanks for the follow up news that the conversion route was successful in allowing you to work with the convert in a Premiere Elements project.
                  Although I will think about it some more, the only alternative to conversion that I can see is producing a file with different properties.
                  AVCHD as video codec should be fine with the .mp4 container format. But, if you are not getting an audio presence in Premiere Elements, it may be the .mp3 audio in the .mp4 container that is creating the incompatibility issue. Not sure. The variable frame can be problematic, but I am not  seeing that as the sole problem for this syndrome.
                  What are the chances of you producing an AVCHD AAC.mp4. instead of the AVCHD MP3.mp4?
                  ATR
                  • 6. Re: Audio from mp4 fails to import
                    MENTALFiST Level 1
                    AVCHD AAC.mp4 fixed the problem!
                    I will use it from now on, thanks a lot for the help
                    • 7. Re: Audio from mp4 fails to import
                      A.T. Romano Level 7
                      MENTALFiST
                      Wonderful news. Great job.
                      Glad you had the opportunity to use the AVCHD AAC.mp4.
                      Best wishes
                      ATR
