2 Replies Latest reply: May 1, 2014 9:31 AM by Kasey1024 RSS
    RH 10: Generating local help using WebHelp to chm Converter; local help does not open.
    Kasey1024 Community Member
      Note: I am relatively new to RoboHelp: formerly a contract writer, a senior staff member used my content when creating Help.  She's left, and now I am using the tools she set up on RoboHelp to write and create both local and remote (online) versions of Help content.
      Have created online versions successfully for several products. Local has been more problematic.
      Using RoboHelp 10; for the past 2 days, tyring to generate local help using WebHelp to chm Converter which uses Webhelp for chm ssl provided by my predicessor.  Files generate successfully and I can open and view them.
      When added to the application, however, they do not open. We're trying to RTM, but gated behind getting a working local help.
      Investigations:
      1. Opened older files (ones that predate me), generated local help, installed chm into current application.  Opened, but did not include the skin. (Is that normal? Can I have the skin in local help?)
      2. Checked current Webhelp for chm ssl against older ones -- only changes are to the "title bar" and "content title" to reflect new name for product.) Also, ealier verision had browse sequence indicated in WEbHelp Settings, Content tab, but none of the indicated files were actually checked.  ALL OTHER SETTINGS THE SAME.
      3. Checked output reports for both ealier local help (that worked) and current (that doesn't). Mostly the files have the same HHC3004 warnings:
      HHC3004: Warning:
      work_with_word.htm :
      The HTML tag "?xml version="1.0" encoding="utf-8" ?" is not a valid HTML tag (it does not begin with an alphanumeric character).
      HHC3004: Warning:
      topics_with_feedback_footer.htt :
      The HTML tag "?rh-region_start type="body" ?" is not a valid HTML tag (it does not begin with an alphanumeric character).
      1. One file has multiple HHC3004 warnings.
      HHC3004: Warning:
      HHC3004: Warning:
      topic_notes.htm :
      (and a few more)
      But since these warnings were for both the successful and unsuccess Local output files, I'm not sure they are relevant.
      Any ideas out there?
      Kasey
